AlZilla Posted September 25, 2025 Report Posted September 25, 2025 41 minutes ago, fredk said: you could solder/braze or whatever to join it and make it more secure You could. That would have to be done once it was through the leather. Depending on the heat source it could be a challenge to not singe the leather Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Contributing Member fredk Posted September 25, 2025 Contributing Member Report Posted September 25, 2025 When I'm soldering anything very close to plastic or leather I wrap a piece of wet cloth around the item, just slightly past the area to be soldered. That keeps the rest from getting too hot Quote Al speling misteaks aer all mi own werk..
CFM chuck123wapati Posted September 26, 2025 CFM Report Posted September 26, 2025 Most of those arent soldered. I doubt you would need to in this case, there is not a lot of weight on it. But if ya want to, then tin them first before putting them on the wallet, then it's just a matter of touching a hot iron to them for an instant. Beware, solder isn't the same color, so it will show, so you have to be careful tinning just the seam. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members bowthemaker Posted October 9, 2025 Members Report Posted October 9, 2025 On 9/25/2025 at 5:06 AM, SR71 said: Hi everyone, I am looking for this specific hardware to tether a chain to a trucker wallet. Anyone know any good sites for this type of hardware? Ideally in both solid brass and nickel options. Many thanks! Hi! I sell short run custom engraved hardware like grommets, snaps and double cap rivets in brass and stainless steel. I'm based out of Toronto. Heres my website and instagram if you are interested. http://www.bowthemaker.com Bow The Maker Let me know if you have any questions. Shane Quote
