Members dikman Posted November 1 Members Report Posted November 1 I made this primarily to use with my lathe but it may be useful for working on sewing machines etc. Copper face one end, nylon the other, copper was melted from motor windings. I found that copper is a pain to turn in the lathe as it galls and creates a rough finish! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
kgg Posted November 2 Report Posted November 2 13 hours ago, dikman said: I made this primarily to use with my lathe but it may be useful for working on sewing machines etc. Very nicely done. It would also be good for hammering down the thread in seams. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
CFM chuck123wapati Posted November 2 CFM Report Posted November 2 heck yeah thats cool. did you try using just a file at slow speed? I do brass but havent tried copper. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members dikman Posted November 3 Author Members Report Posted November 3 It's funny stuff, my first cuts were using a carbide bit and it actually caused the bit to chip! I reverted to a sharp high-speed steel bit and that went fine until it galled, left a surface with little raised bits on it. I then took very light cuts to smooth it out , used a fine file and sandpaper and finished off on a buffer. Brass is much better to work with on the lathe, I don't think I'll be doing much more with copper. It was an interesting experiment, however, and at least copper doesn't give off those nasty zinc fumes when it's melting. Having said that, kgg got me thinking - a hammer-head profile like a cobbler's hammer might be nice, copper has the weight for it. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
CFM chuck123wapati Posted November 3 CFM Report Posted November 3 Interesting indeed. Maybe throw some tin in with it; bronze might turn better on the lathe. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members dikman Posted November 3 Author Members Report Posted November 3 I haven't got any tin although I saw a chap mix 10% aluminium with it, made it tough enough to hold a bit of an edge! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
