The very basics of getting a good seam are:
i) correct machine threading
ii) correct top & bobbin tension
iii) correct needle system for your machine
iv) correct orientation of the needle
v) correct needle type (ex. 135 x 16  for leather and 135 x 17 for fabric)
vi) correct size of needle to handle the top thread
vii) This next step is where people seem to be having a problem. Getting the seam started. You really need to hold both the top and bobbin thread as you start your seam.
That can be a royal pain grabbing and holding those threads particularly with smaller sized thread like v69 and v92. If you don't hold both together weird things can happen like jams, bird nesting, skipped stitches, etc.
A quick solution is:
Tie both threads together by a simple knot. Chances are now you will be able to grab the threads and put consistent tension on both threads at the same time.
viii) Locking the threads
a) Typical method is sew forward 3 or 4 stitches and then reverse to lock the stitches then continue with forward stitching.
b) More Advanced Method is start your stitching 3 or 4 stitches in and reverse sew back 3 or 4 stitches. The seam threads will be locked when you sew forward but with less thread bulk in the needle holes.
kgg
Edited by kgg
  • CFM
nice!!!
