I have the steel flat plate on my Cowboy Outlaw. I also have the edge guide. When the flat bed is installed it makes the edge guide tilted to one side. My question then is are these two supposed to work together or are they mutually exclusive? Any help and guidance greatly appreciated.  Pics attached i hope
The guide appears to be for the JUKI 441 + clones. So w/o knowing the CB Outlaw but knowing Singer 45K´s, Adler 5 / 105 and so forth I´d say either flat bed or edge guide. A suspended flip up edge guide probably is the better option when working with a flat bed.
maybe something like this
https://de.aliexpress.com/item/1005008728390412
or check this thread:
or you make a flat bed attachment where you can screw on an edge guide or modify yours.
I once made this FBA for my Singer 45D91 but on mine I cannot use the 441 roller edge guide but the OEM Singer 45K edge guide that mounts on the flat bed steel plate insert. Note the 3 holes in line. Thats where I can mount guides and accessories.
Edited by Constabulary
