Members MsDragonfly Posted February 11, 2009 Members Report Posted February 11, 2009 when making a holster to hold a square shape object, do I need to cut v-notch grooves where I want my leather to bend ( shape out to be a 90 degree angle )???? will grooving it help or just wet it and bend it?***Lisa Quote
Members MsDragonfly Posted February 11, 2009 Author Members Report Posted February 11, 2009 when making a holster to hold a square shape object, do I need to groove it with a v-gouge where I want my leather to bend ( shape out to be a 90 degree angle )???? Or should I just wet it and bend it?***Lisa Quote
tashabear Posted February 11, 2009 Report Posted February 11, 2009 It depends on how thick your leather is. Quote
Ambassador Luke Hatley Posted February 12, 2009 Ambassador Report Posted February 12, 2009 I HAVE BEEN KNOWN TO CUT EITHER A "V GROVE" OR A" U GROVE" THEN WET AND FOLD. Quote
Members Rawhide Posted February 12, 2009 Members Report Posted February 12, 2009 For thicker leather, it's almost imperitive that you groove the folds. I even take a french edger after that and put one leg in the groove and hold it at about a 45 deg angle and take off some of the side on both sides of the groove. Quote
Members Dwight Posted February 13, 2009 Members Report Posted February 13, 2009 (edited) when making a holster to hold a square shape object, do I need to cut v-notch grooves where I want my leather to bend ( shape out to be a 90 degree angle )???? will grooving it help or just wet it and bend it?***Lisa I use a pair of sheet metal bending pliers, . . . they look like a "wide jaw" version of pliers. Ask for them at a hardware store. They work real well on Glock holsters where I have to make a 90 practically at the stitch line. Use water just a little hotter than your hand can stand, . . . soak it, . . . then grab it with the pliers and bend, . . . forcing the front of the pliers down into the fold, . . . works great for me. May God bless, Dwight Edited February 13, 2009 by Dwight Quote
