Members Lippy Posted April 20, 2009 Members Report Posted April 20, 2009 Jim, Do you have any suggestions for making a general purpose clamp set? What about overall dimensions? Are they hinged at the bottom? Please tell us newbie's more. You've always have great stuff. Cheers! Quote
Contributing Member barra Posted April 20, 2009 Contributing Member Report Posted April 20, 2009 The overall length of mine are 41 inches. From the botton to where it starts to bend is 20 inches, the jaws are 20 inches and 3 inches at the widest. The extra 1 inch difference is where the 2 halves are screwed together. The timber halves are 1/2 inch thick. You can make them longer to suit the individual by adding another length of timber at the bottom and screwed in place between the 2 halves. Barra Quote "If You're not behind the Troops, please feel free to stand in front of them"
Members Lippy Posted April 20, 2009 Members Report Posted April 20, 2009 Barra, Thanks for the measurements and the photos. I did find some "steam bending wood" videos on Youtube. That seems to me the best way to build them rather than trying to cut them out with a bandsaw. Have you ever seen any clams that are hinged at the bottom? Cheers, Lippy Quote
Contributing Member barra Posted April 20, 2009 Contributing Member Report Posted April 20, 2009 Other than the version that Oldtimer posted, no I have never seen them hinged. Barra. Quote "If You're not behind the Troops, please feel free to stand in front of them"
hidepounder Posted April 20, 2009 Report Posted April 20, 2009 Years ago...back in the 70's, Bill Porters Sadlle Shop, here in Phoenix, purchased some stitching horses that were made of steel. They had forged clamps and all the linkage to operate the clamps was located below the seat so that the entire clamp was open to hold leather. They were extremely strong and comfortable with padded seats. Has anyone ever run across one of these or know if they are still being made? Bob Quote
Members jimsaddler Posted April 20, 2009 Members Report Posted April 20, 2009 Years ago...back in the 70's, Bill Porters Sadlle Shop, here in Phoenix, purchased some stitching horses that were made of steel. They had forged clamps and all the linkage to operate the clamps was located below the seat so that the entire clamp was open to hold leather. They were extremely strong and comfortable with padded seats. Has anyone ever run across one of these or know if they are still being made?Bob These were probably from Old Harry downs from Frankston, Vic, Australia. He did tell me he sent several lots the the US. Someone told me they had a set, now I can't remember who it was to get a copy. It worked with a car spring on the out side from memory. I actually had a set and they were strong, good for learners. Kindest Regards. Jim. Quote
Members jimsaddler Posted April 20, 2009 Members Report Posted April 20, 2009 Jim,Do you have any suggestions for making a general purpose clamp set? What about overall dimensions? Are they hinged at the bottom? Please tell us newbie's more. You've always have great stuff. Cheers! Lippy Thankyou for your kind comments, I will try to get a photo posted of several Clams including a hinged one made from a piece of 3" x 3" pine that is hinged. For the best Clams though they should be Steamed or you can cheat by using Boiling Water on the ends to be Bent. If you can get Hickory, Oak, Spotted Gum, Lemon Wood or any flexible Hardwood in aprox 4 x 5/8" double Dressed. Keep pouring Boiling water on aprox 12" from the best end. You make a jig to form the bend about the thickness of a house Brick, in fact I saw a Brick used once to form Clams. the idea is to force the heated timber into the size curve you want plus a bit more, by Clamping down on the timber to hold the shape. Let it dry for a few days then release it. If you have soaked it (or Steamed) well enough and it is hot enough it will only spring back a small amount. Then you get at the 2 halves with a Horse Shoe Rasp and shape your Clams identically (Mirror Image) to suit. Then champfer the inside of the Jaws so that they will allow the working edge to come to-gether. I actually like this edge to be prominent for Strap stitching and flat to-gether for Saddle Flaps and the like (less likely to scratch). These are then Screwed to-gether at the bottom end and a Heavy Screw is used 1/3rd of the way up to provede tension. The Hinged Clam is simply cut out on a Band Saw to shape, sanded till it looks and feels right then one jaw is sawn off and and a Hinge screwed to re-join it and a 5/16 Bolt Wing Nut used to tighten the Jaws to-gether. A Seat Spring is used between the Jaws to open them (Bolt goes through the Spring). A long flap of Apron Split is used as a cover so the Thread doesn't catch the Wing Nut. Please excuse me delaying the Photo's as I can't work out how to get them loaded so I'll work on it. Kindest Regards. Jim. Barra's Clams can be made also by the Steam method and just insert a Leg into the Jaws. Quote
hidepounder Posted April 20, 2009 Report Posted April 20, 2009 These were probably from Old Harry downs from Frankston, Vic, Australia. He did tell me he sent several lots the the US. Someone told me they had a set, now I can't remember who it was to get a copy. It worked with a car spring on the out side from memory. I actually had a set and they were strong, good for learners.Kindest Regards. Jim. That sounds right Jim, I had forgotten about the spring, but I think there was one. Thanks....wish I could find a pic of one.... Bob Quote
Contributing Member barra Posted April 20, 2009 Contributing Member Report Posted April 20, 2009 Jim. Barra's Clams can be made also by the Steam method and just insert a Leg into the Jaws. As per the smaller set of clams in the photo with the 2 sets. Barra Quote "If You're not behind the Troops, please feel free to stand in front of them"
gtwister09 Posted April 21, 2009 Report Posted April 21, 2009 Bob, Good luck.... I have had my eyes peeled for about a decade for one of those. Regards, Ben Quote
