electrathon Posted March 26, 2009 Report Posted March 26, 2009 It has been a while since I have posted any pictures. This was a Tandy kit. As usual, there were a few issues with the kit. I generally throw out the leather that comes with the kits, as the quality is about equil to cardboard. I started carving the piece that came with this one, but by the time I had it carved I decided that the piece would make a better templet than a carving. I replaced it with a piece of leather I had from a better quality hide. It was tooled using the pattern in the kit, The only changes I made in it was I added basket weave to the center of the circle in the back. It just looked so bare.It is antiqued with Sheridan Brown Feibings paste antique, applied over two layers of RTC finish. After it was assembled, I realized that the pattern should have been shifted about 3/8"-1/2" down. Also the hole punched for the snap was in the wrong place (it is a little too tight when closing). I also did not use the incorectly spaced round holes for the lacing. Unfortionatly you can see them on the inside. Aaron Quote
TomSwede Posted March 26, 2009 Report Posted March 26, 2009 Purse looks very good!! The colour them is nice and well matched with the dualtone braid! Nice carving too! Tom Quote Confucius - Better a diamond with a flaw than a pebble without. --------------------------------------------- www.1eye1.se blogg.1eye1.se
MarkB Posted March 26, 2009 Report Posted March 26, 2009 Nice Job Aaron like the two tone lacing. Mark Quote Visit My Website To succeed you must try, Not trying your sure to fail.
electrathon Posted March 27, 2009 Author Report Posted March 27, 2009 Thanks guys. I started two tone lacing most of my work a while back. It always seems to draw attention. It is not really any harder than regular lacing, but gives things a unique look. Quote
carr52 Posted March 27, 2009 Report Posted March 27, 2009 It has been a while since I have posted any pictures. This was a Tandy kit. As usual, there were a few issues with the kit. I generally throw out the leather that comes with the kits, as the quality is about equil to cardboard. I started carving the piece that came with this one, but by the time I had it carved I decided that the piece would make a better templet than a carving. I replaced it with a piece of leather I had from a better quality hide. It was tooled using the pattern in the kit, The only changes I made in it was I added basket weave to the center of the circle in the back. It just looked so bare.It is antiqued with Sheridan Brown Feibings paste antique, applied over two layers of RTC finish. After it was assembled, I realized that the pattern should have been shifted about 3/8"-1/2" down. Also the hole punched for the snap was in the wrong place (it is a little too tight when closing). I also did not use the incorectly spaced round holes for the lacing. Unfortionatly you can see them on the inside. Aaron Aaron is hard to get the two tone to go around corners? I know I have trouble trying to do it with the Mexican round braid. Love the look. I'm gonna have to try it. Tom Quote
electrathon Posted March 27, 2009 Author Report Posted March 27, 2009 Aaron is hard to get the two tone to go around corners? I know I have trouble trying to do it with the Mexican round braid. Love the look. I'm gonna have to try it. Tom The two tone laces just like double loop lacing, you just keep switching laces every other one. The pattern I used is the same one as you used on your wallet, just used two laces instead of one. So corners are just as easy/hard as regular lacing. I generally round the corner a little (very little, about 1/8" radius) and then hit two of the holes twice. If I am trying to get a pointed corner I round hole punch the corner and hit it 4 times. Quote
carr52 Posted March 27, 2009 Report Posted March 27, 2009 The two tone laces just like double loop lacing, you just keep switching laces every other one. The pattern I used is the same one as you used on your wallet, just used two laces instead of one. So corners are just as easy/hard as regular lacing. I generally round the corner a little (very little, about 1/8" radius) and then hit two of the holes twice. If I am trying to get a pointed corner I round hole punch the corner and hit it 4 times. Well heres my stab at it. I'm not going to use 2 tone on this project but I used it just to try it out. The only thing I had to work with. Your right it is easy to work with but I had to get out the book and I haven't done a corner yet. Thanks again for your help. Tom Quote
electrathon Posted March 27, 2009 Author Report Posted March 27, 2009 Well heres my stab at it. I'm not going to use 2 tone on this project but I used it just to try it out. The only thing I had to work with. Your right it is easy to work with but I had to get out the book and I haven't done a corner yet. Thanks again for your help.Tom When you get to the corner do the same thing as you are doing but double hit the 3 holes on your corner. Think of it like you are moving forward, just overlap. The trick with the two colors is when you are coming around the last corner count forward to make sure that the two tone pattern will meet corectly on the last stitch. If is does not, simply add an extra double hit on the final corner hole. What you have done so far looks great! Quote
electrathon Posted March 30, 2009 Author Report Posted March 30, 2009 I am open to critique here is anyone else wants to chime in. Aaron Quote
Members MikeV Posted April 27, 2009 Members Report Posted April 27, 2009 ----- This was a Tandy kit. As usual, there were a few issues with the kit. I generally throw out the leather that comes with the kits, -----Aaron Aaron, I am new to Leathercraft and am taking lessons at my local Tandy. I was wondering why you buy the kit if you normally use other leather? It seems to me that if you wanted better leather than comes with the kits, you would just buy the leather you want and get your patter elsewhere. What am I missing? Thanks, Mike Quote This is the day which the Lord has made, RELAX and have fun in it. Mike
