Members Kevin Posted April 4, 2009 Members Report Posted April 4, 2009 I've only been burning my thread instead of cutting it for maybe three or so years. I had been using cheap soldering irons, but after going through maybe four or five, I decided to try the thread burner Weaver's sells. It does a fantastic job burning thread. The only problem is,it is so light weight and small, I have a lot of trouble controlling it. I never burned myself with the soldering irons, but I burn myself with this all the time. I covered the handle with leather like a maul handle, thinking that would add some weight and thickness, but it doesn't help much. I even had a Homer Simpson moment when I burnt a finger, recovered, and started to change needle size and grabbed a hot needle the burner had been up against. Kevin Quote
Members Rayban Posted April 4, 2009 Members Report Posted April 4, 2009 I use a Zippo. Quote Raybanwww.rgleather.net
Members Double U Leather Posted April 5, 2009 Members Report Posted April 5, 2009 I'm not nearly as technologically advanced as some of you.....I use Diamond kitchen matches. Quote
Moderator Art Posted April 5, 2009 Moderator Report Posted April 5, 2009 Bovie Art Kevin said: I've only been burning my thread instead of cutting it for maybe three or so years. I had been using cheap soldering irons, but after going through maybe four or five, I decided to try the thread burner Weaver's sells. It does a fantastic job burning thread. The only problem is,it is so light weight and small, I have a lot of trouble controlling it. I never burned myself with the soldering irons, but I burn myself with this all the time. I covered the handle with leather like a maul handle, thinking that would add some weight and thickness, but it doesn't help much. I even had a Homer Simpson moment when I burnt a finger, recovered, and started to change needle size and grabbed a hot needle the burner had been up against. Kevin Quote For heaven's sakes pilgrim, make yourself a strop!
Members Casey Jordan Posted April 5, 2009 Members Report Posted April 5, 2009 Mark me down for a bic too. Quote Casey Jordan www.caseyjordansaddle.com www.artofthecowboymakers.com Q: Do you have A.D.D.? A: Look, there's a chicken
Members joppstack Posted April 5, 2009 Members Report Posted April 5, 2009 I've used a lighter for years and it does the job. Sometimes though when using light colored leather you can burn it if you're not careful. About a year ago I bought something called "perfect end thread burner". It's about the length of a pen and about as big around as a nickel and uses a AA battery. When you push the button it instantly heats the end of a wire loop red hot to cut and melt the thread. When you let off on the button it is completely cool to the touch in about 2 seconds. It really does a good job. I like the fact that it does not have to be plugged in and it's small size and that you don't have to wait for it to heat up. The only negative thing I've found is that if you use it alot it does use up the battery rather quickly. I purchased it online from a sewing supply co.... I can't remember the name. Proleptic sold this tool under a different name, "Pro-thermal pen" I think I paid about $25.00 for it, I think Proleptic's was a higher price, I think around $35 - $39.... Hope this helps..... Neil Quote
Ambassador pete Posted April 5, 2009 Ambassador Report Posted April 5, 2009 ask your doctor for a cauterizing instrument. They get them free from the reps. It looks like a big sharpie with a little wire loop. push button, instant on, cools immediately, Had one for 11 years and haven't used up the (non replaceable) battery power yet! Quote
Members Kevin Posted April 6, 2009 Author Members Report Posted April 6, 2009 We have reps park in our lot all the time for the Dr. next door, I think it's time to start charging. Thank you, I'll have to give it a try, Kevin Quote
Members Ameliarita Posted November 25, 2016 Members Report Posted November 25, 2016 What are the advantages and disadvantages of burning thread? Quote
Members JerseyFirefighter Posted November 27, 2016 Members Report Posted November 27, 2016 I've used a bic primarily. Got suckered into buying the thread zap 2 (the wire loop burner) and my thoughts are I got about 3 days out of a AA battery, and it lasted 2 weeks before it quit on me. I always made a practice of putting the rigid plastic cap back on it as not to damage the seemingly fragile loop end. Now stupid me goes ahead and buys a butane torch off of amazon last week thinking its time to upgrade. Unfortunately it was either the rum that did it or the lack of pictures but what I thought would have been 4" mini torch turned out to be a full fledged chef's torch that is entirely too big for burning thread. I may be looking to try something different as ive noticed after some moderate use, the threads I burn tend to fray again and look a little sloppy. Maybe im just not cutting close enough to the stitch hole, but that's a whole other thread for another topic. Speaking of which, anyone have a good recommendation of a quality close quarter sewing scissor? Quote Rob www.ridgewayleatherworks.com IG: @Ridgewayleatherworks FB: RidgewayLeatherworks
Members Big Sioux Saddlery Posted November 27, 2016 Members Report Posted November 27, 2016 I use a cheap soldering iron with the finest point I can get. I just plan on replacing it 2 or 3 times a year. After a few months of use the tip is either shot or it doesn't heat as hot. I want to be able to get as close as possible and not take a chance on burning the leather or something else that I don't want to burn, which is why I don't like a lighter. Quote
Chief31794 Posted November 27, 2016 Report Posted November 27, 2016 (edited) I use a cheap thread burner that I got off of Ebay, instant on, uses 1 AA battery, battery lasts a month of so, no chance of scorching leather which I used to do from time to time when using a lighter. The point on this thing lets me burn the thread into a "Ball" recessed into the hole it came out of, locks the stitches and barely shows at all. Works exceptionally well on machine thread (277), works for hand stitching as well but takes a second or two longer to melt the thread. It looks like this. Chief Edited November 27, 2016 by Chief31794 Quote "Life's too short to carry ugly leather"
Members billybopp Posted November 27, 2016 Members Report Posted November 27, 2016 I used to use a lighter, but occasionally burnt the leather if not very careful. Tried an old soldering iron, which worked well but they take awhile to heat up, so not very convenient for burning a thread or two now and then. I've recently started using a battery powered thread zapper, and really like the kind that has a retractable tip so that I don't accidentally burn something I shouldn't, and to protect the wire when not in use. Rechargeable batteries are also a good idea since they do go through batteries fairly quickly. Bill Quote
Members Sonydaze Posted November 27, 2016 Members Report Posted November 27, 2016 (edited) I use the Thread Zap II as well. They are a bit hard on batteries but work well on getting close without damaging other thread or the leather. They heat fast and cool off quickly. For the speed and conciseness, I will happily buy batteries. The tip is a bit fragile, so I recommend getting a spare. Several vendors on Ebay sell them: http://www.ebay.ca/itm/Thread-Zap-II-Burner-Zapper-Tool-Cordless-Beadsmith-Beading-Embroidery-Crafts-/302140393506?hash=item4658f88822:g:NEwAAOxyaTxRS3N8 Edited November 27, 2016 by Sonydaze Correct typo Quote http://www.bound2please.com Sewing machines: 3 - Sunstar 590BL, Artisan Toro 3200, Juki LK-1900HS, Juki DDL-8500-7, Juki DDL-5550N, Pfaff 138-6/21, Pfaff 546-H3, Pfaff 335-H3, Adler 221-76, Singer 144WVS33, Singer 29K-51, Siruba 747B
Members JerseyFirefighter Posted November 27, 2016 Members Report Posted November 27, 2016 On 11/27/2016 at 3:53 PM, Chief31794 said: I use a cheap thread burner that I got off of Ebay, instant on, uses 1 AA battery, battery lasts a month of so, no chance of scorching leather which I used to do from time to time when using a lighter. The point on this thing lets me burn the thread into a "Ball" recessed into the hole it came out of, locks the stitches and barely shows at all. Works exceptionally well on machine thread (277), works for hand stitching as well but takes a second or two longer to melt the thread. It looks like this. Chief Expand Maybe I got one of the bum ones. I saw after I had purchased it that a few reviews had the same problem that I had. I just had suspected they neglected theirs. I couldnt have been more careful with the darn thing. Quote Rob www.ridgewayleatherworks.com IG: @Ridgewayleatherworks FB: RidgewayLeatherworks
Chief31794 Posted November 28, 2016 Report Posted November 28, 2016 On 11/27/2016 at 6:01 PM, JerseyFirefighter said: Maybe I got one of the bum ones. I saw after I had purchased it that a few reviews had the same problem that I had. I just had suspected they neglected theirs. I couldnt have been more careful with the darn thing. Expand Maybe I got a good one, never know. Mine is about 2 years old and I've replaced the tip once, use it a lot, goes through batteries pretty well, but mine works great. Chief Quote "Life's too short to carry ugly leather"
Members DuncanSinclair Posted December 2, 2016 Members Report Posted December 2, 2016 I have this: https://proleptic.net/shop/tools/pro-thermal-tools/pro-thermal-cordless-thread-burner/ works like a champ! Quote Chris Anderso,n KC9UVB Member -IILG Greenwood #514, F&AM
