The whole rig looks great! I loved both shows.
And if you are interested in obtaining a mare leg - check out:
http://www.jbcustom.com/mares.htm
There is also a picture of a couple of holsters for it.
Cheers!
Edited by Studio-N
"Out of my mind.....back in 5 minutes"
  • Replies 27
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Badger,
Count me as a Firefly fan also. As others have said it's a nice job and a very good vintage look.
Regards,
Ben
Tony,
It's a chopped Rossi 92, Winchester clone.
It has a saddle ring on the left side of the receiver block. The ring slips over a hook at the top of the 'slab' section and the spring clip retains the fore end. If you walk around with it, you need to tie it into the clip with a thong, just to be sure.
Gina Torres wore the rubber stunt version in the rig more often than not.
Much lighter :thumbsup:
Cheers,
Badger
Thanks, Karl.
Just finished this commission for a fellow Firefly fan.
This is a replica of Zoe's rig from Joss Whedon's Firefly. The gun is the original hero Mare's Leg used in the show.
It's a substantial rig, about 7mm thick all over. The fore end clip was interesting to figure out. The inert cartridges are 45 Long Colt, the originals were 44/40 cal.
The buckle was cast from the original and I copied all the dimensions over. It's as close as I can make to an exact copy.
What do you think Tasha?
Badger
I think it's GORGEOUS. How did you do the distressed effect?
Thanks guys.
The original had a colourful and varied past which included being in many TV shows and movies. After Firefly, the original holster rig finally ended up on 'Deadwood'..... until I rescued it.
They'd cut the belt section down by about 11 inches and moved both strap billets, losing the four-bullet stash on the front, and sanded all the original surface off to make it look 'older'.
All the original stitching marks were still there, so I made the pattern for this replica by 'restoring' the original, but only on paper.
I drew it all out and put everything back where it was supposed to be.
It uses a lot of leather, being fully lined :lol:
Tasha, the distressed effect is done by making a 10% wash of Fiebeings dark brown oil dye and dappling the surface with it. The darker colour is artists acrylic black paint, let down with water and sponged on. As it started to dry, I removed selective areas of paint by rubbing with a damp sponge to simulate wear. The liner is straight oil dye, dark brown. Skidmore's and a carnuba wax finish.
When thoroughly dry, I gave it all another a good coating of carnuba wax and a brisk rubdown.
In many ways, it's a better quality piece than the original. The fittings and billets are all sewn to the outer. The liner is completlely smooth.
Yes Ray, this piece was sewn on the 'Pilot' :yeah:
Cheers,
Badger
Edited by badger
How did you make the bottom clip Badger? Is there metal in there?
Thanks,
Art
Art Schwab
"You cannot teach a man anything. You can only help him discover it within himself." – Galileo Galilei
Art,
The clip is a galvinised steel pipe clamp from the hardware store.
It's one of the 'U' shape clamps with a right angled foot at each side on the bottom to screw to the wall. The first foot is bent back and hammered completely over to make a safe, rounded end. The other end is bent straight to form an extension of the clamp body with a mounting hole in it.
I measured the clip and cut and sewed a leather sleeve for it. I cased the sleeve and worked it over the clip, then boned it down. The clip is secured through the outer leather and internal 'slab' (A heavy piece of leather, cased with very hot water to make it stiff) with a thread-locked Chicago screw. It emerges through a slot in the outer.
Cheers,
Badger
Edited by badger
That replica is awesome Badger!!
Love it, looks very true to the original that you show in the pics with the girl.
Great job, I'm jeaolus!!
Tom
Confucius - Better a diamond with a flaw than a pebble without.
www.1eye1.se
blogg.1eye1.se
Thanks Tom,
It was fun figuring out the colour scheme. I think it turned out pretty well.
I just got a call from a client asking me if I can make a Blade Runner holster for him. It's open fronted with an internal spring clip.....that's a challenge!
Cheers,
Badger
