Jaymack Posted April 2, 2012 Report Posted April 2, 2012 http://www.wrtcleather.com/ In my opinion the worlds best unknown leatherworker, everything he touches to my knowledge is hand stitched. Yep, I've learned from his tutorial! http://wrtcleather.com/1-ckd/tutorials/_leatherstitch.html Quote
Members LeatherLegion Posted April 28, 2012 Members Report Posted April 28, 2012 Still learning for now but here is my best so far... i also posted a picture in "Critique my work" too .I don't have the courage yet to hand stitch anything else but left-overs...1 ply pieces of leather...lol...This one here is 5 stitches/inch and i am using #415 thread . I tried a straight line and also a curve...which i thought it's gonna be a bit more harder. I just got my hands on some linen and that's gonna be my next project . Any oppinions are more then welcome..especially critiques. Thank you ! Quote
Members jk215 Posted May 3, 2012 Members Report Posted May 3, 2012 Yep, I've learned from his tutorial! http://wrtcleather.c...therstitch.html I just read through this tutorial and not sure if I understand his process. First he pokes his holes on the face, then glues, then pokes again all the way through. After that goes to the other side and pokes back through to even it out. So hes doing a total of three rounds? Would this also apply to things like wallets? Quote http://shop.makesupply-leather.com - Custom and Stocked Acrylic Templates
Members daviD A Morris Posted April 29, 2015 Members Report Posted April 29, 2015 i was looking for the linen thread and saw that they sell it in both left and right spun options, i figured i would ask why? i mean i didn't think there would be a difference but there must be if they make both options thanks When hand stitching, a person stitching right-handed is best using a "right-hand lay" or "S" twisted thread. If you use a "left-lay" thread it tends to come un-twisted. I'd been stitching for 14 years before I went to england and found that out. When I started in the trade we made all our own threads and naturaly enough they were right hand twist, thats how you make them. I've been having trouble sourcing right-hand lay linen thread here in Australia. #29 ouchmyfinger can you tell me where were you looking to scource it? thanks dam Quote Remember to drink the coffee not the edging dye!
Members 25b Posted April 29, 2015 Members Report Posted April 29, 2015 There are multiple threads on here that state that "S" and "Z" threads only make a difference in use in sewing machines. Quote
Members bkm Posted April 29, 2015 Members Report Posted April 29, 2015 I also became convinced that S and Z threads do make a difference in hand stitching. However, it is not based on whether you are left or right-handed. The difference is made based on whether your stitching twists S, Z or is straight. As you lay the cables through the awl holes, is one cable passing over, under, over under... or the other, or is one always on top. If you always stitch with the same needle-handling, you will be twisting them S or Z because the needles are alternating and your hand technique is not. If you alternate your needles and your handling technique, then they will be straight. A right-handed person can use either S or Z twisted cable, but they should pay attention to whether their stitching is twisting the two cables S or Z, or straight. Quote
Members bkm Posted April 29, 2015 Members Report Posted April 29, 2015 Here are two Z-twist cables in Z-twist Here are two Z-twist cables in S-twist I didn't do anything to these cables except twist two of them together either S or Z, the same way they would be twisted were they stitched in leather, except I twisted them more turns per length than most stitching would result in to exaggerate the effect. Quote
Members bkm Posted April 29, 2015 Members Report Posted April 29, 2015 (edited) I just read through this tutorial and not sure if I understand his process. First he pokes his holes on the face, then glues, then pokes again all the way through. After that goes to the other side and pokes back through to even it out. So hes doing a total of three rounds? Would this also apply to things like wallets? It doesn't make sense to me to punch the leather three times. Every time you put the awl in, you're cutting some leather fibers making the leather weaker around the hole and making it so the hole will close-up to a larger size. Ideally, the awl only pushes the fibers to the side, the needle goes through with the thread, and the fibers close-up around the thread. Practically, the awl cuts some fibers. The fewer the better. Edit: reading more carefully, it looks like the welt being sewn amounts to 6 layers of 8 oz. which would be 3/4" of leather. I regularly sew up to half an inch with a single awl pierce but I have not tried 3/4". I imagine the technique is to obtain good alignment of the holes through all the layers. Edited April 29, 2015 by bkm Quote
Members goodfella Posted May 1, 2015 Members Report Posted May 1, 2015 one I did a few years ago not doing any hand work at all anymore Quote check us out at www.jrussellleather.com Email Jack Russell leather please visit Jack Russell leather on facebook and like us
Boriqua Posted May 18, 2015 Report Posted May 18, 2015 (edited) Here's a couple of photos of some sewing I did the other day that turned out pretty good. The cantle binding and inlaid seat were both handsewn in the first photo, the second photo shows a handsewn horncap. People sometimes ask if I sew saddles with a dremel drill... personally, I find it insulting but I guess it's people who just don't know any better. D. Dude you are my new hero!!!!!! That is stunning stitching Edited May 18, 2015 by Boriqua Quote
