I think its the tannery. I use to think that maybe its tandy from having the stuff out in a store but I dont think thats usually the case. Ive gotten that a few times but usually in smaller areas and honestly trying to clean it doenst really help atleast in my case. Its like its something from when it was tanned so theres not much you can do for it.
Ive only scene it in there thicker stuff (8/9). That is also the only leather that I have scene the spongy problem I had with a few pieces.
One thing I would like to add is that you will probably have a problem dying it as well. Even if you get it cased properly.
  • Replies 24
  • Created
  • Last Reply
Top Posters In This Topic
But I've never had leather not absorb water -- it literally beaded up on the surface! And I cut the previous book cover from the bit right next to this. Why is this piece behaving so differently?
I have had the same happing - I shared a double shoulder with a friend: my piece, no problem! Half of the part he took, would not soak in the water; and it is he who told me about his remedy, which was saddle soap.
This might be an altogether case, but you never know. Because it is an organic material, leather is not predictable. When I decorate leather by oxidizing it, water will bead on the still-wet part of the leather. And yet, when it dries out I can so a second oxidizing without a problem at all. It makes it an interesting hobby!
JOhan
****Afrikaans: Leerwerker *****  ****Zulu: lesikhumba isisebenzi  Latvian: ādas darba ņēmējs *****Russian: кожа работника ****English: Leatherworker ****Dutch: Lederbewerker ****Flemish: Leerbewerker ****Hebrew: עור פועל ****German: Leder Handwerker ****Hungarian: Bőrdíszműves ****Turkish: deri işçisi ****French: Artisan du Cuir ****Spanish: Artesano de Cuero ****Norwegian: Skinn kunstners ****Swedish: Läderhantverkare ****Greek: δερμάτινα εργαζόμενος  Sotho: mosebeletsi oa letlalo
Then why, when I cut another bookcover from the same side, the same area of that side, did it case just fine? Seriously: these two pieces shared a cut line. If it was the first piece I'd cut from that side I'd agree with you, but it's not.
It's just so weird...
maybe the hide sat in a "crumple" long enough to damage it?
in just a section of the hide.
I think that I would wet down the whole thing and see what happens.
(this from the fabric chick)
Reality is for people who lack imagination
Whether you think you can or think you can't - you are right. ~Henry Ford
  • 2 weeks later...
If a combination of acetone and sandpaper won't do it, try leaving it as is, if not for this particular project, then for the next. If this leather looks different than all other leathers, make something unique out of the hide's unique look. How hard would it be to reproduce that exact Rorschach on a different piece of leather? You've got something special there. Make the most of it.
Take it back to Tandy with your photos and ask them to verify the defect by casing it themselves. They should replace the leather. You should not have to wash your veg-tan in acids or deglazers. Tandy should be providing a veg-tan product that is at minimum caseable.
My $.02.
:red_bandana::red_bandana::red_bandana:
Ride Safe!
Bree
2003 Dyna Wide Glide
Memberships:
Iron Butt Association, Niagara Falls HOG, Wild Fire HOG
NRA, Niagara County Sportsman's Association
Wow, that's a new one on me. Never seen veg tan do anything like that before. Has to be in the basic tanning process. Looks like they began to stuff it and changed their mind. Are those scratches on the leather also? Simple solution: use a different piece of leather for now and take that piece back!
The couple of times I have had it the noncasable portion was either a small circle or are about 10" roughly. Not huge but big enough. Another time it was the lower portion toward the belly about 1/4 of the belly section, kind of like ya dipped it in something.
That being said I have not ran into it very often. However I have also shyed away from getting leather from tandy lately. For me atleast it was a 50min drive with a bridge toll so it just wasnt feasable anymore.
I had the same thing happen to my last seat I started, I started tooling it anyways for practice, but will also try the saddlesoap to see if it fixes it. I cut a piece from right next to it and it is fine.
  • 5 weeks later...
as i am new and learning about this stuff...
forgive me if it's a certain type of sponge that you use but thought i'd give some input re: sponges
If it is the typical aborbing good sponges you buy from the groc. store I wonder if this is what could be what had happened...
I bought a couple of packs of sponges different times...and they felt spightly lightly damp when I opened the packages...
I just thought that the first time I opened up a pkg that perhaps the store I got it from the whole box gotten wet (as I live in a wet/ damp type of climate as I live near the ocean.
After buying a new pkg of sponges a month later again it was alittle damp kind of I went back to the store and looked closely at all the sponges same thing for all......I then searched the net as I was questioning if / why sponges were like thins...
Surprisingly I had found out that new sponges are soaked slightly to prevent sponges from allowing bacteria breeding and other stuff. I don't know what the stuff they put sponges in then it is pkged but it isn't water.
You have to give a good good rincing of the sponges . Apearently it's a safe non-toxic liquid..I'd check with other pkgs of where you bought your sponge from see if got this stuff in it...(look at the clear plastic to see if there is a inside film...or buying another sponge and check if it's a sponge free of this liquid or has this liqid stuff....by squeezing the sponge you can't tell unless you actualy feel directly the sponge itself...( i found that they started doing this over the last few months...
le us know what you find out what happened
Lea
