More additional information: TK mentioned using sawblades. While you can make a blade from it, it is far from ideal. I made a small knife out of one and found the following:
Sawblades are typically made from L6 steel. For its purpose as a sawblade, it's good. There's a reason that lots of sawblades have carbide tips though.
L6 can be water quenched, and will take a dandy edge, but it rusts....very quickly. I haven't found a way around this, other than lots of oil, which is not so great for leather.
L6, while hardenable, doesn't hold up like good tool steel.
Other good steels to use for beginners are 1095 (very forgiving), and 5160 spring steel (common source: the rusted out jaloppy in the field). A search on knife maker forums will yield more info.
Mike DeLoach
  • Replies 31
  • Created
  • Last Reply
Top Posters In This Topic
hey thanks for the info I am not a metalurgist so I really didnt know what type of steel was used in a saw blade. One question though to temper it would I just heat it red hot like mentioned and water quench. or do I need to do another step like the oven? I think I will try it just to see if I can do it, I have never tried anything like this so if I ruin some old saw blades I am not out any money. and one more. Can I use my oxy/acetylene set up or would that put too much carbon in the steel?
Tim Worley
TK-Leather
If you don't ask and dont try how are you gonna learn anything?
Thanks,
Art
Art Schwab
"You cannot teach a man anything. You can only help him discover it within himself." – Galileo Galilei
Do not quench in water, use oil. The water tends to make it brittle. If you are going to try using your torch use the rosebud tip. Also, box it in somehow to make a makeshift oven so that the blade heat will be more consistant. You do not want one part of the blade being a couple hundred degrees hotter than the other parts.
I have made round knives from hand saw blades. It works well.
so I use oil to quench. How hot do I need to get it for how long? Cherry red? then quench in oil then do I need to place in oven for a while? Sorry but I want to try this but when I am done I want the dang thing to hold an edge.
How do your knives hold an edge? reasonable time or do you have to strop after every few cuts?
Thanks for all of the info.
Tim Worley
TK-Leather
When I am using handsaw blades, I do not re-temper them. I cut them out and then sharpen. They likely fall about 55 on a rockwell scale, so they are good but not great. 65-70 hardness would be awsome, hard to sharpen but will stay that way for a long time. Personally, I sharpen everything nowdays on a belt sander, then move on to a "cardboard stone" on a grinder with rouge on it. I can take a unfinished knife to razor sharp in a couple minutes. When I am carving I do still constantly strop, I do it all the time, no matter what knife I am using.
Tomcats explanation of temp was great. Use a magnet and keep testing to see if it sticks. Once it is hot enough, it will no longer stick, quickly do the quench. You can only harden the edge (some sawblades are like this) but I have always done the whole knife.
Hardness on a knife is a double edged sword. If the knofe is easy to sharpen, it will dull quickly. Hard to sharpen and it will hold an edge for a long time. Kitchen knives are a good source of steel to work with. Chicago Cutlery is a good steel, there are many others. If you are at the thrift store pass up the shiney ones, the knives that have a duller finish are better quality. Old files are great steel too, depending on how hard you want to work to shape it though.
Tkleather, if you are uncomfortable with hardening or tempering, you can make the basic head knife and send it to this company and they will do it for $5.50 per piece, you would have to use a different steel like D2 because they only do air hardening, you can call them, they are very helpful and tell them what you want to do and they should keep you on track...Tom..
http://www.texasknife.com/vcom/privacy.php#services
well thanks for all of the info, once I catch up in the leather shop I will try to make one or two.
Tim Worley
TK-Leather
  • 2 months later...
Thank you all it was my pleasure to do it....I, like a lot of others have gotten tons of infomation from the unselfish people on this forum who readily give their secrets away...If something is not clear, feel free to contact me, and remember the info for heat treating and tempering is for O1 steel only, other steels differ, some greatly...Have fun and above all be safe...Tom
8/17/09
Thanks for starting this Thread and for teaching us all that, Tomcat. I'll save the link to this Thread. And, thank you all you 'other people' who each know about different specialties.
TexasLady
Edited by TexasLady
You are quite welcome TexasLady.... :) ...Tom
