I'd like a machine that will sew two pieces of leather with chunky stitching. Like this [which was hand saddlestitched]
I'd also like to be able to sew handbags someday. I've been in contact with someone in Australia who sells Cowboy machines and he recommended a 7441AE, but it's very expensive. He said my budget option is a Master 105.
Does anyone have any advice for me?
Hi Ruteless,
I have a singer 45k, cylinder bed machine this type of machine will do what you want easily,
mine is old and does not have reverse but you can work around that, the problem I have is it is to fast for me, I am going to fit a servo motor
and a speed reducing pulley, in Australia the real good ones from a dealer are selling for about $1200-$1800.
These machines are built like a tank, they are almost impossible to break,
If you only want a flat bed then a 132 k6 would also do the job being a flat bed it is just a bit less versatlie
Edited by china
You will definitely need some form of heavy duty stitcher to do this type of work. The Cowboy 441 clone and the 105 are good machines, and they work quite well for this type of work. The only other option would be to find a used machine like the Singer 45K, or maybe an older used Adler or something of this nature. But, the price of the Adler and Singer machines can cost almost as much as a Cowboy machine is new.
Ryan O. Neel
Cowboy Sewing Machines
Neel's Saddlery and Harness
Offices in North Lima Ohio and Toledo Ohio
www.cowboysew.com
www.neelsaddlery.com
toll free: 1-866-507-8926
What makes this need such a heavy duty machine? Looks like Artisan 618 class or I'm sure you have very similar size or the Cobra class 17 or 18 should easily do that thickness of leather. Or, am I missing something? Or, does it simply need a cylinder arm?
Regis
God, Family, and Country (although liberals are attempting to destroy these in the USA)
Regis
It is not the thickness of the leather. It is the size of the thread. The Cobra Class 17 and 18, and the Artisan 618 will at most handle a size 207 thread. And even the size 207 thread is really pushing the limits of what those machines are capable of. We also sell machine like the 618 and class 17 and 18, and these machines struggle with a 207 thread.
The bigger machines like the 441 and 105 and others will handle a much larger size of thread.
The thickness of the material is prety thin, but the size of the thread (chunky) would mandate that a larger machine capable of handling the thick thread be used.
Ryan O. Neel
www.cowboysew.com
Ryan,
Thanks a lot for clearing that up. ' just couldn't see the problem and now I understand.
Regis
Do youself a really huge favor.
take some material you use and go try some machines. take the spool of thread you want to use too. same for those handbags you plan on making in the someday. find/get some of the leather you plan on using including the threads.
if you cant afford one now, save you pennies until you can get what you need. if you dont, you will always kick youself for buying the lesser machine.
alot of people dont have the $$$ to do it right the first time, but they will come up with the $$$ to do it twice.
Edited by $$hobby
Riding is a partnership. The horse lends you his strength, speed and grace, which are greater then yours. For your part you give him your guidance, intelligence and understanding, which are greater then his. Togeather you can achieve a richness that alone neither can.
- Lucy Rees, The Horse's Mind
I would have to agree, it is better that you save up tp get the right machine for the job, rather than skimp and end up buying what you should have bought in the first place.
Ryan O. Neel
www.cowboysew.com
Some great advice here, thanks :)
Part of the problem is I don't know if there's a store in Sydney where I can walk in and look at different machines and talk to someone in the know. Birdsalls only sell the Tipman Boss. The guy I've been in contact with is in Queensland, which is making it really hard for me to make my mind up. He's being very patient and helpful!
I can get the more expensive one if you all reckon it's the right one for the job. Trying it out first would be a BIG plus though.
If availability limits your choices, get the most machine you can. It's better to have an over powered machine that'll stitch dang near anything, and use only a portion of it's potential than it is to get a smaller machine that strains to do what you need. You never know, you might end up making tack, too.
Cylinder arm......absolutely unnecessary for collars. Very handy for bags. If you get a cylinder arm, you can get/make a flatbed attachment for it. You can't shrink down a flatbed for times you NEED a cylinder arm.
Buy new if at all possible. If you have to get a used one...well, privately owned machines may not have as much mileage, but also may not have much maintenance. Used factory equip will have more mileage, but are likely to have been well maintained.
Mike DeLoach
