Members club49 Posted July 25, 2015 Members Report Posted July 25, 2015 Hi Bob, I am new here and just wanted to thank you for all your help. I have your step by step instructions on how to do edges stuck to my wall. My edges come out great, now I have to work on the rest of my work. Jim
Members lilsiscojoe Posted July 27, 2015 Members Report Posted July 27, 2015 Can any type of leather be cased (latigo, harness, etc)? To stretch and shape it? Like for a knife sheath? Maybe this is not the right place for this question??
Members camano ridge Posted July 27, 2015 Members Report Posted July 27, 2015 If it is veg tanned and has not been pre loaded with waxes and or oils, or have a finish on it can be wet molded.
hidepounder Posted July 27, 2015 Author Report Posted July 27, 2015 Can any type of leather be cased (latigo, harness, etc)? To stretch and shape it? Like for a knife sheath? Maybe this is not the right place for this question??I can't really answer that question because I've never tried to case latigo or harness leather, but my first thought would be that it would not case. My other thought is that neither of those leathers would be the appropriate choice for projects that need to be molded. If it is veg tanned and has not been pre loaded with waxes and or oils, or have a finish on it can be wet molded.I would think the answer is yes. The best leather for a project that needs to be molded is veg tan.
Members Hawk Scarbrough Posted October 24, 2015 Members Report Posted October 24, 2015 On 9/16/2009 at 5:17 PM, hidepounder said: Hello everybody... I have put together the steps I take to case my leather for tooling due to a number of requests regarding my method. I hope this will clarify what I perceive are some misconceptions about what casing leather really is. It is in PDF format and Johanna has graciously added the article to the "Tips and Tricks" section where anyone can find it. Thank you Johanna!!! Or it can be accessed through the link below. I hope those who need this find it helpful.... Bobby I like to moisten my leather on large multi piece projects..place them in ziplock bags...and put them in the fridge. I then take out the piece I'm going to work on tooling and let the leather return to near normal color. Hint: Either have a tolorant wife, as I do, or be a bachelor, ha.
Members catstamp Posted November 4, 2015 Members Report Posted November 4, 2015 (edited) Thank you Bobby for taking the time to pass on your knowledge to us newbies out here. I am learning as I go and I appreciate getting good advice from a pro like yourself. Edited November 4, 2015 by catstamp
Members grommit Posted March 3, 2016 Members Report Posted March 3, 2016 thank all for the thread on casing. it help me massively. ATB Bri
alpha2 Posted July 10, 2016 Report Posted July 10, 2016 (edited) The thing that led me astray as a newbie was Tandy Leather videos where they said again and again that casing was done by saturating the top surface with a wet sponge, then waiting until it almost returned to the original color. That may work for some thin leathers in small sizes, but it's a far cry from the proper way to "case" leather. I finally know why I wasn't getting consistent depth and color to my stamping. I can't wait until I use this method for my next project! Edited July 10, 2016 by alpha2
Members JenGranger Posted December 15, 2016 Members Report Posted December 15, 2016 On May 8, 2011 at 3:23 PM, Bennie lovejoy said: If I may ask a question about casing? Is it best to case all leather or just large pieces? I usually don't use anything larger than say an 8" by 10" piece for knife sheaths and just use a wet sponge before tooling. is my logic OK for this? My impressions very rarely come out the same. I have the same question about small projects.
Members catstamp Posted December 16, 2016 Members Report Posted December 16, 2016 You can wet leather but just that simple act is not cased. When casing leather you want the moisture to reach the inner most fibers of the leather and that take's time and a bit of planning. Once the leather return's to its normal color and is cool to the touch the moisture has swollen those inner fibers and then it's ready. Cased leather will cut easier and your impressions will be crisper
hidepounder Posted December 17, 2016 Author Report Posted December 17, 2016 I've received several emails regarding this thread and so i'd thought I'd weigh in. There is absolutely nothing wrong with wetting the leather and then tooling it. To me that is sort of the norm and I often do that myself. The advantage to casing, as some of you have mentioned, is to (1) aid in cutting, (2) extend tooling time, (3) aid in the "burnish" or color you get with the tools. It is not necessary to case overnight. The process can take just a few hours, which is depedent upon the environment. Many of us case over night because it's convenient to prepare tomorrows leather, today. Also, it is not necessary to use the refrigerator. The only reason to refrigerate is to prevent mold growth. Mold growth only happens when the leather has been too wet for too long in a warm environment. Finally the true differnece between cased leather and wetting the leather is this. Leather is cased only when ALL the fibers contain the same amount of moisture when the leather is in a TOOLABLE state. To achive this, the leather must be placed in a super humid environment, where evaporation has been slowed to a crawl. So SOME evaporation is required. This is why casing boxes work better than plastic bags. If you are using a plastic bag, it's necessary to let the leather dry somewhat before it is sealed in the bag. Old coolers make good casing boxes, especially when small adjustable vents are added to the sides and top. I hope this is helpful and Happy Holidays, everybody! Bobby
hidepounder Posted December 18, 2016 Author Report Posted December 18, 2016 On 12/15/2016 at 8:04 AM, JenGranger said: I have the same question about small projects. Bennie Lovejoy & JenGranger... Your logic is fine. As I've stated before, casing is not a requirement to produce better work. It's just another "arrow in the quiver" so to speak. Will casing small pieces of leather provide a better result? Probably, but that's something only you can really answer thru trial and error. You know a lot depends on your particular environment, the quality of your leather and the difficulty of the tooling pattern. You may very well discover that when doing small pieces that you can finish in a single sitting, just don't require casing. I think it would be a good idea to try both methods and then evaluate the results. As far as having inconsistent impressions goes, i'd have to see exactly what you're referring to. In general inconsistent impressions can be caused by a number of things such as moisture content, quality of leather and inconsistent strikes. Tool quality can take it's toll also! Hope this helps! Bobby
Members JenGranger Posted December 18, 2016 Members Report Posted December 18, 2016 Thanks Hidepounder!
Members masahiro0 Posted February 16, 2017 Members Report Posted February 16, 2017 Thank you so much for all those valuables information Hidepounder!! I've tried to let my leather ''case'' longer, at ambient temperature (small piece,max 8*4 inches, over a 3-4 hours time),instead of tooling them right after wetting them and letting them absorb the water. It did wonder on my last piece. The burnishes are finally showing! I've wet my last piece yesterday, and have put it in a ziploc bag overnight, since i'll be tooling it tonight. Do i need to let it dry for a 3-4 hours as i usually do , or will it be tool-able quite quickly since the job has been done overnight in the bag? Thanks again! *an amazed newbie
hidepounder Posted February 17, 2017 Author Report Posted February 17, 2017 It depends entirely on how wet it was when you put it in the plastic bag and the humidity in your environment. If it had turned partially back to it's natural color, then it should be toolable soon. But if it was very wet when it went into the bag, then you will have to wait and it won't be properly cased. To case properly, the leather has to breath a little but must remain in a super humid environment while it returns to color. Old ice chests make good casing boxes, especially if a couple of adjustable air vents are installed. Hope this helps! Bobby
Members ContactCement Posted March 28, 2017 Members Report Posted March 28, 2017 I dipped a piece of dyes leather for 4 seconds into cold water and it took 12 hours to come close to normal color and the imprint isn't deep. The leather left the granite surface plate was moist too. This method seems somewhat opposite of the sponge video and leather craft book. Also some people say I should not practice stamping on pre dyed what looks like 5- 7 oz leather veg scrap sold in mystery bags at the hobby stores. The pre dyed stuff seems to absorb water and darken when wet and returns to its previous shade though. Yet requires several strikes to make an imprint.
Members catstamp Posted March 28, 2017 Members Report Posted March 28, 2017 Without seeing the type of leather you are using its hard to completely answer your concerns. It sounds as though you are latigo leather. Which is a dyed waxy leather that isn't good for tooling and doesn't case. It's used for harnesses or items that may be exposed to weather or heavy use. I imagine when you wet it the moisture was trapped against your granite because it doesn't absorb into the grain. Call SpringfieldLeather Co. and get one of their veg tan remnant bags. Then, wet it on both sides either with a quick dip or sponge.... I'm sure you will experience a difference with it. Good luck!
NVLeatherWorx Posted March 28, 2017 Report Posted March 28, 2017 21 hours ago, ContactCement said: I dipped a piece of dyes leather for 4 seconds into cold water and it took 12 hours to come close to normal color and the imprint isn't deep. The leather left the granite surface plate was moist too. This method seems somewhat opposite of the sponge video and leather craft book. Also some people say I should not practice stamping on pre dyed what looks like 5- 7 oz leather veg scrap sold in mystery bags at the hobby stores. The pre dyed stuff seems to absorb water and darken when wet and returns to its previous shade though. Yet requires several strikes to make an imprint. Most pre-dyed leather isn't veg-tanned (which is the ONLY leather that is suited for stamping or carving & tooling) and from what you are describing you have one of those pieces that ISN'T intended to be stamped or decorated. It is most important to first learn about the ways leather is tanned and which tanning method results in how each type of leather is used before you go spending ANY money on leather, even scraps, for test/practice purposes. This basic information is available everywhere and will save your "hide" (little leather joke there) before you make an expensive mistake. Do yourself a huge favor and start researching leather and how it is tanned and used and you will be a much better craftsman for doing so. To learn how to work with leather you must read and research everything there is out there, otherwise you are just wasting your time and then wasting others by asking why something doesn't work when you could have known for yourself. This is a very common thing with new leather workers and you don't want to be in that group.
Members chrisash Posted March 30, 2018 Members Report Posted March 30, 2018 Great posts and explanations of what its all about, seldom only one correct answer to question, but i think you have all added a lot of good information i can use from now on Many thanks to you all
Members BDAZ Posted March 30, 2018 Members Report Posted March 30, 2018 I only use drum dyed veg tan leather for commercial work. It saves time which is money, is very consistent for order refills and allows me to limit my color offerings. I do find it a bit trickier to case the leather due to the dying as the changes are more subtle. I would ask for some natural veg tan scarps to play with. Bob
Members Squid61 Posted March 5, 2019 Members Report Posted March 5, 2019 Is the casing .pdf still available? Can't seem to get the link to work.
Contributing Member fredk Posted March 5, 2019 Contributing Member Report Posted March 5, 2019 seems to be a dead link. I PM'd you a copy
Members animalcraker Posted March 5, 2019 Members Report Posted March 5, 2019 4 hours ago, fredk said: seems to be a dead link. I PM'd you a copy May I get a copy too please
Contributing Member fredk Posted March 5, 2019 Contributing Member Report Posted March 5, 2019 Done, I PM'd you a copy
