hello leather community,
I would like to start with a giant thank you for all the warmth and respect shown on this site making the introduction to leather craft fun and inspiring!
I am going to beat on this horse a little about finishes. I have been using resolene as a resist and finish but honestly I am not happy with the out come as the dye bleeds thru when I test it with water and I have read in the past post about this being a common issue. what I would like a bit more clarification on is the bees natural finish, bees rtc, it seems these two are able to stop the dye/color from bleeding onto clothes or skin like for belts and cuffs. so is it the rtc that I need or the bees natural wax finish. a few of my projects are going to wet environments although I simply don't want bleeding no matter what the conditions.... and then there is the simple function of body sweat from the wearer. when my projects are dry the dye (feibings professional oil dye) will stay put after atom wax, or mink oil. or resolene but I am having a hell of a time keeping in the dye once I splash a little water on it. I have gone far back in the archives to read on this topic and I have still one question how can I keep the dye in the leather once the water hits it. I understand about the lacquer finishes being an option but I think I am more interested in a wax finish as I understand better the flexibility and barrier abilities of wax much better then lacquer I will apologize now for the redundancies but I am frustrated and I just have to beat on this to find a solution.,
thank you to anyone able to shine a big light on this helping to clarify the bee natural product right for the job from the first hand users.
my steps are as follows:
* carve
* dry
* oil
* slick edges
* dry
* oil again
* dry
* antique or dye
* dry
* tankote
* dry
* burnish/finish edges
* finish (the mystery solution) no bleeding???
REVOLUTION LEATHER
one side fits all
I would:
* carve
* dry
* oil
* slick edges
*dye
* finish with RTC. Practice with the stuff, use it wet and more than you think you need. You only have a very short time to spread it out.
* antique
* tankote
* dry
The RTC is not as durable as neet laq, but it is good for a water based product. There is a learning curve. Most people try to be too neat ond work slowly, this does not work. Put it on wet, thick and fast. Work it around till it gets sticky and get away. Usually less than a minute.
Hi... Very few finishes are waterproof... That RTC stuff is really pretty close... But it really takes a build up of several light coats to get the best effect. You might call the folks at Bee Natural... I'm sure they'd be happy to give you all the help they can. (nice folks) Neat Lac is maybe something that you ought to try. Once you learn how to use it, it really makes a nice finish. Again, it really needs to be thinned, and a couple of light coats are better than a heavy one. Usually, neat lac needs to be, (or should be) thinned almost right out of the can. Sheep wool is a good applicator. The problem with tan kote is that it really isn't very water resistant... and that's what you're putting on last. So, when water hits it, it will go right thru. After you've applied the tan kote, and it's dried, try a light coat of Neat lac, and see if that doesn't help. Do it on practice pc tho....
Happy experimenting! :)
kevin
kevin, what do you thin neat-lac with?
charlie
I'm never to old to learn about all the things life brings along.
I would:
* carve
* dry
* oil
* slick edges
*dye
* antique
* tankote
* dry
see I thought the rtc was a wax, I didn't realize it was water based... thank you
REVOLUTION LEATHER
one side fits all
kevin
thank you it seems this is the direction I should take... I will give it a try to see if the dye stays put.
crissy
REVOLUTION LEATHER
one side fits all
I want to follow this...
Tandy does not produce (or have produced) Neat-Lac anymore. However LCI makes an identical product called Clear Lac, Kevin has it at Springfield, and Vandy has it at Sheridan Leather Outfitters. There is also a thinner for it called LCI Thinner (imagine that). When you use the thinner, it will reduce the gloss some. Prices?
Clear Lac $16.99 quart
Thinner $13.99 quart
Those are usual retail.
Art
good question! anyone?
Art
art, thank you ...... thank you to everyone! I am going for it!
carve on!
REVOLUTION LEATHER
one side fits all
