Members alberta Posted November 22, 2009 Members Report Posted November 22, 2009 I would like to build a extension table for my recently purhased 29 k 62 .does anyone out there have a drawing or good pictures that i could refer to ? Quote
Members celticleather Posted November 22, 2009 Members Report Posted November 22, 2009 (edited) Hi Alberta I have a Singer 29K table, and recently let another member have the dimensions and some pics. I've attached them here. Measurements are as follows (in millimetres) A=115mm B=80mm C=45mm D=25mm The length of the arm is 312mm (this is the short-arm version) I have also traced around the inside of the slot, and the result is on the attached pdf. The file has been reduced to 50%, so if you print it out and photocopy or scan it to 200%, you should arrive back at original size (or just get the measurement back to 318mm by whatever means!). Hope this is what you need. Terry (celticleather) slot.pdf Edited June 1, 2023 by Northmount Removed redundant images/file Quote When everyone is somebody, then no one's anybody
Members alberta Posted November 22, 2009 Author Members Report Posted November 22, 2009 Hi Alberta I have a Singer 29K table, and recently let another member have the dimensions and some pics. I've attached them here. Measurements are as follows (in millimetres) A=115mm B=80mm C=45mm D=25mm The length of the arm is 312mm (this is the short-arm version) I have also traced around the inside of the slot, and the result is on the attached pdf. The file has been reduced to 50%, so if you print it out and photocopy or scan it to 200%, you should arrive back at original size (or just get the measurement back to 318mm by whatever means!). Hope this is what you need. Terry (celticleather) thanks terry for the great pictures they are very helpful Quote
Members stumpy Posted May 31, 2023 Members Report Posted May 31, 2023 Could you please send me the dimensions of the extension table for the 29k so that I can make one as well .I have tried to dovn load them from your sight but can,t unless I have your permission, Meny thanks ray. Quote
Northmount Posted June 1, 2023 Report Posted June 1, 2023 17 hours ago, stumpy said: Could you please send me the dimensions of the extension table for the 29k so that I can make one as well .I have tried to dovn load them from your sight but can,t unless I have your permission, Meny thanks ray. If you are logged in, which you had to be to post this, everything in this thread is available to you to print, copy, download. Just checked and all works. If you are logged in and still can't download the info you require, there is something wrong with your connection, router, or browser that you will need to fix. Quote
Moderator Wizcrafts Posted June 1, 2023 Moderator Report Posted June 1, 2023 19 hours ago, stumpy said: I have tried to dovn load them from your sight but can,t unless I have your permission, Disable any ad and scripting blockers for our website. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
