Members Jimbob Posted January 15, 2010 Members Report Posted January 15, 2010 Hi Tim & Odin, I may hate to say this but I've been using Rubbing Alcohol for about 30 years now, to thin my Spirit dyes. Tim when you say it ruined something,,, what happened? I've never had any problems at all,,, now you've got me wondering. Here are a few things I've done using Rubbing Alcohol thinned Spirit dyes. Ed the"BearMan" Dye or no dye, alcohol or Methyl...(I prefere Tecquila) I just thought the fumes blew me away...then I realized it is the awesome carving and the flow of colors you do!!! Well maybe it is the Tecquila, but I like it!!! Since I use spirit dye I will try both and see what it does....( Then have some Tecquila...haha...) Thanks for great post!! James Quote http://www.elfwood.com/~alien883 First it is just leather....then it is what-ever I can dream off...
TimKleffner Posted January 15, 2010 Report Posted January 15, 2010 (edited) Ed I had made several ohm meter cases and they wanted them dyed brown. I started running low on dye and thought I would thin the dye for the last case. I thinned the dye with rubbing alcohol, then daubed on the dye to the leather. After it all dried, the case shrunk and appeared burned. These were the days before my air brush. Now, I use only de-natured alcohol to thin and spray all my large one color items. I spray all my belts with the new mixture and never have problems. Ed, you've got some awe some work there. your application is quiet different that what I did. Happy tooling Tim Edited January 15, 2010 by TimKleffner Quote It's hard to fail, but worse never to have tried to succeed.Theodore Roosevelt
Members ChuckBurrows Posted January 15, 2010 Members Report Posted January 15, 2010 (edited) FWIW - Like Ed I've been using Isopropyl aka rubbing alcohol for 40+ years as dyw thinner/suface cleaner and have had no ill effects. According to the Fiebing MSDS the dye contains ethanol (from which denatured alcohol is made), isopropyl, and methanol..... Edited January 15, 2010 by ChuckBurrows Quote Wild Rose Trading Company Two roads diverged in a wood, and I, I took the one less traveled by, And that has made all the difference.
Members CitizenKate Posted January 16, 2010 Members Report Posted January 16, 2010 Good to know, Chuck. Thanks for adding your input. Kate Quote
Contributing Member ClayB Posted January 16, 2010 Contributing Member Report Posted January 16, 2010 Me 3. I've use isopropyl alcohol to reduce spirit dyes and oil dyes. It's always worked fine for me. Quote ClayB Badlands Leather Art blog Badlands Leather Art Website
Members wanabe Posted March 19, 2014 Members Report Posted March 19, 2014 I have made a few projects using Fiebing's applied with a dauber. I could never get the even, streak free job I wanted. I put some denatured alcohol in a plastic pan and added dye until it looked like what I wanted on a couple of pieces of scrap. Dipped seven pieces and ruined four projects. Some came out too light, some way too dark and some had light spots and speckles. I don't know if or how I can salvage these as I have put in quite a bit of work on them. Any info on treating the leather before dipping to get an even, consistent job? How about ideas/info on salvaging my work? Quote
Members marine mp Posted March 20, 2014 Members Report Posted March 20, 2014 Wanabe, I hate the pieces are ruined, but most projects are salvagable. I always used isopropyl alcohol to thin my Feibings dyes. I now use Angelus dyes and haven't looked back since and I still thin with alcohol. Now for the leather prep. I always put the pure neats-foot to it before dyeing as it seems to even out the color. JMHO.. Semper-fi Mike Quote "The first one thru the door...gets the copper-coated candy". ADL Custom Holsters "I've got a LONG list of real good reasons, for all the things that I have done"!!!
King's X Posted March 25, 2014 Report Posted March 25, 2014 Interesting responses.......MarineMP....I do opposite of you. I lightly wet my leather before applying my Fiebing's dye and haven't had any streaks. After the dye dries, I apply a light coat of oil and let it sit overnight or most of the day before I continue. Quote Greetings from Central Texas! The Grain Side Up blog #TheGrainSideUp
Members JoyceLee Posted April 11, 2014 Members Report Posted April 11, 2014 Another question: is Feibings Pro Oil Dye suitable for bracelets and belts? Quote
