Based on the Tandy reenactment project sheet, I give you my Q&D rapier frog!
Pattern can be found at :
http://www.sclcg.org/flasah/flashafiles/eswordhanger1.html
http://www.sclcg.org/flasah/flashafiles/eswordhanger2.html
Modifications:
  • Tandy no longer makes the buckles or chap snaps mentioned in the parts list. I substituted different buckles. The chap snaps are only 3/4" so I modified the cut pieces to accomodate the smaller size. It's only really noticable on the rear strap support.
Immediate problems:
  • The chocolate brown I used on the flesh side bled through to the grain around the holes in the billets and main body.
  • The buckles are a bit too long.
  • I got lazy and didn't neatlac the pieces before I started putting them together.
  • I can't cut straight, so none of the edges are true, they're all a little wavy.
But, for a really quick and dirty test to see how well the pattern held up, I think it turned out pretty well. What do you guys think?
Edited by MHolzer
I'm in the same boat as you in the cutting dept....but I think your frog came out really nice! I've seen this pattern, in fact a friend of mine made it too and I sold it for him at a Faire. Yours is great for just practice! I think the knot is just right on it - not crowding all over the piece. I'm kind of a minimalist when it comes to design on pieces like that -- you don't want it to detract from a fine blade in my opinion.
I cheat when cutting anything with curves. I find a dinner plate, saucer, small bowl, or other similar item in the kitchen and then I use my knife blade against it as I would against a straight edge. It takes a lot of firm downward pressure on the plate or saucer to keep it from sliding, and you might want to actually mark it first with a pen so you can be sure the cut line is where you want it in case it does shift, but that's how I do it. Maybe it will help, although your edge doesn't look all that wavy to me : )
Nice work, by the way!
~Tammy
  • 5 years later...
Ok, resurrecting this one to ask, does anyone have a rapier frog pattern? The links in this post are broken and I really like the look of it.
Don't suppose anyone still has these patterns? The links are broken and it's just what I've been looking for.
I used to make some (with not exactly the same form) a while back, I will dig in my pattern folder, I'll post it here if I find it !
Here's my pattern, I took the time to redraw it on Inkscape because the paper pattern was in a bad state. However I can't find photos of the frogs I made with it. I hope the diagram is clear.
frog.pdf
frog.pdf
That's odd, I didn't think I'd posted twice on this? Oops!
Thank you so much for the patterns, they're just what I need :)
  • 1 month later...
That's pretty good work! I made something similar a few years back:
