Members Storm Posted April 7, 2008 Members Report Posted April 7, 2008 This is a new design have beeen working on the carving is just simple on this one as that is what was requested. Have some cooler one coming. Quote Please keep in mind that unless I ask for anyones critique I do not want nor require same.
HorsehairBraider Posted April 7, 2008 Report Posted April 7, 2008 That's nice. What a great idea - my card case is currently metal. That's such a nice way to show off your work. Quote They say princes learn no art truly, but the art of horsemanship. The reason is, the brave beast is no flatterer. He will throw a prince as soon as his groom. - Ben Jonson http://www.beautiful-horses.com
Members Storm Posted April 7, 2008 Author Members Report Posted April 7, 2008 Thanks Jacquee, Have to say thanks but wait till I get some of the otehrs on the site. Went to your site and was very imporessed. I make jewelry on occasion too but your braided horsehair is awesome. That along with some many other forms of cowboy art are slowly diminishing. Those of us who work with our hands have a deeper apprec ation for what it takes to create so many things. Hope that my hands don"tr succumb to arthritis. Even then I am reminded of the great impressionist painter Monet who suffered from a crippling and painfull version of arthritis. O e of his associates asked him why he still painted as just the act of holding the brush was so painful. He would continue for as lo g as the beauty was still coming out of his fingers. I have a theory though....if you don't use it you loose it... and along those lines I figure that the use of my fingers and hands and ever so occasionally my brain might stave off the potential of that sort of thing. Hope to be seeing more of your work on here soon. Thanx, Storm Quote Please keep in mind that unless I ask for anyones critique I do not want nor require same.
Ambassador Luke Hatley Posted April 7, 2008 Ambassador Report Posted April 7, 2008 I like that design, it looks to me like it would be easy to pull the card out, vs the 2 pocket ones, you dont mind if i use this do you? Quote Luke
Members Storm Posted April 7, 2008 Author Members Report Posted April 7, 2008 Thanx Luke, What I found t be helpfull is to put it all together and then prior to finishing I soak the inside pocket with a damp sponge and the slowly take old plastic credit cards and insert the one bu one while flushing each successive card to one side or the other. I occasionally tap them into place with a nylon hammer. I then use a molding tool to to form a molded pocket and smooth it out. I just leave the cards in place until the leather is dry. You end up with a pocket that will hold more cards than if you don't. I did one recently for a friend who was a schizophrenic. Wanted two pockets for two different cards he carries. Storm Quote Please keep in mind that unless I ask for anyones critique I do not want nor require same.
Ambassador leatheroo Posted April 7, 2008 Ambassador Report Posted April 7, 2008 nice work storm, good design, looking forward to seeing more Quote "]http://leatheroo.blogspot
Ambassador Luke Hatley Posted April 7, 2008 Ambassador Report Posted April 7, 2008 Storm said: Thanx Luke,What I found t be helpfull is to put it all together and then prior to finishing I soak the inside pocket with a damp sponge and the slowly take old plastic credit cards and insert the one bu one while flushing each successive card to one side or the other. I occasionally tap them into place with a nylon hammer. I then use a molding tool to to form a molded pocket and smooth it out. I just leave the cards in place until the leather is dry. You end up with a pocket that will hold more cards than if you don't. I did one recently for a friend who was a schizophrenic. Wanted two pockets for two different cards he carries. Storm Hey Man thanks ..... that is what i was going to do. already have a ps of 3/8 plywood cut out for the moulding... Quote Luke
Ambassador Beaverslayer Posted April 7, 2008 Ambassador Report Posted April 7, 2008 Nice looking work Storm, great idea as well with forming the pockets to be a bit bigger. Ken Quote Beaverslayer Custom Leather<br />Wearable Works of Art https://www.facebook...erCustomLeather
Members Storm Posted April 7, 2008 Author Members Report Posted April 7, 2008 Here is another thought. If you are going to use wood then I might suggest sanding off the rough edges and giving it a nice coat of polyurethane to protect from moisture. If you were going to use it alot then I might suggest having it cut from plastic. Better yet maybe three pieces of 1/4 thick plastic. Then put two pieces in to thepocket to be formed and the gently tap and insert the third between the first and second. Sort of a gradual strech in that way. Good luck. Storm Luke Hatley said: Hey Man thanks ..... that is what i was going to do. already have a ps of 3/8 plywood cut out for the moulding... Quote Please keep in mind that unless I ask for anyones critique I do not want nor require same.
TomSwede Posted April 7, 2008 Report Posted April 7, 2008 this was a neat little thing! I immediatly saw the potential for converting this to a type of memorycard/lenscloth etc. holder to have on the straps for my camerabag aswell. Nice stuff! Tom Quote Confucius - Better a diamond with a flaw than a pebble without. --------------------------------------------- www.1eye1.se blogg.1eye1.se
Members Storm Posted April 8, 2008 Author Members Report Posted April 8, 2008 Great idea Tom. Lets take it a bit farther and put a snap closure but swap out the crown with a concho. Tandy has these cool kits that have screws and spacer/washers . You just screw the concho to the snap with the tailormade screw. Check out this site called www.conchos.com. Real great prices and nice stuff. TomSwede said: this was a neat little thing! I immediatly saw the potential for converting this to a type of memorycard/lenscloth etc. holder to have on the straps for my camerabag aswell. Nice stuff! Tom Quote Please keep in mind that unless I ask for anyones critique I do not want nor require same.
Members Myriam Posted April 9, 2008 Members Report Posted April 9, 2008 Nice looking! I like it I'll have to try making one especially that now, I don't have any excuse for not doing it. What a great idea, using plastic cards to stretch the leather and form it. Hadn't thought of that. Thanks! Quote Myriam Myriam's Leather Work Dakota Braiding and Leatherwork
Members zman7458 Posted April 9, 2008 Members Report Posted April 9, 2008 way to go storm. that is a great idea and a nice peice. looking forward to seeing more. Quote Its not the destination its the journey.
