Members CitizenKate Posted February 6, 2010 Members Report Posted February 6, 2010 *sigh* I send along care instructions with all my "big" items, like game boards and chair seats, that include the line: - Avoid exposing the game board to prolonged periods of direct sunlight. This guy only had this board 3 months, the emailed me asking, "I keep my game board sitting out with my Chess set on it. How come it's getting dark circles where the pieces are?" I replied, "Has it been sitting in direct sunlight?" No answer, until about 3 weeks later, when he asked me how much I would charge to re-dye the green squares. I sent a quote and he sent the board back. This is what can happen, boys and girls, when people leave dyed leather in direct sunlight too long. I've had to re-do dye jobs before, and I wasn't looking forward to this. There's no telling how the color turns out after stripping and re-applying everything... and this one turned out rather nicely the first time. I decided to just try stripping the green squares, and leave the rest of the board as much intact as possible. It's taking more time to surgically remove the sealing finish and antique from just the green squares, but it seems to be working out pretty well so far. I'll post more, as I progress with the restoration. Kate Quote
Members RWB Posted February 6, 2010 Members Report Posted February 6, 2010 I'm curious what type of dye it is that you use. Why do you have to strip it off before you can re-apply it? Can't you simply go over the top to even it all out? Ross Quote Ross Brunk www.nrcowboygear.com
Members CitizenKate Posted February 6, 2010 Author Members Report Posted February 6, 2010 I use different types of dyes, depending on the project, but in this case, I used spirit dyes (Angelus). All the dyes I've used will fade with enough exposure to direct sunlight, some more than others, and greens and blues are especially prone to fading. A sealing finish helps to slow that process, but there is nothing that I know of that can totally prevent it. *AHEM* Attention: dye manufacturers... do you think you could develop dyes that are more light-fast? Please? The reason I strip the leather before attempting to re-applying dye is that the dye does not absorb as easily into the leather over a finish. Here are some test samples to show you what I mean... Kate Quote
Contributing Member JLSleather Posted February 6, 2010 Contributing Member Report Posted February 6, 2010 Had my experience with this ... and THEN started printing out the "warning". Made a painting for this girl ... lake scene in the mountains, fall colors in the trees, reflected in the lake. Nice, even from my worst critic (me). I carved it in 5 oz leather (18x24) and set it a couple inches deep in a beveled, cove-cut oak frame. TOLD her to her face ... not in direct sunlight. A year later I saw it ... on a display easel in front of the window (uggggghhhhh). Apparently the frame had been broken, so she did this instead. Fiebing's spirit dye had faded to basically nothing. Told her I'd repaint it, but the leather itself had darkened considerably. I offered to make her a new one, with the understanding that she won't do that again. But, since the thing was originally ordered for her as a gift she didn't want to replace it. Ordinarily, I probably wouldn't be quite that outgoing, but this is a girl who is always paying me (just called yesterday to say her boyfriend needs a new belt). Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members RWB Posted February 6, 2010 Members Report Posted February 6, 2010 (edited) The reason I strip the leather before attempting to re-applying dye is that the dye does not absorb as easily into the leather over a finish. Here are some test samples to show you what I mean... Kate Interesting. What do you use for a top coat? I've notice that the alcohol dyes take longer to soak thru Neat-lac or Tan-kote, but I've never had that problem of them barely soaking in. Maybe I put my colors on to heavy. Intriguing. Not that it matters, you have a system that works for you. I was just curious. You do some cool stuff, Kate. Ross Edited February 6, 2010 by RWB Quote Ross Brunk www.nrcowboygear.com
Members CitizenKate Posted February 7, 2010 Author Members Report Posted February 7, 2010 I use either a wax or lacquer finish (as shown in the samples). I add Tan-Kote to the antique. Now I'm curious, Ross... do you normally put your dye on over your sealer? Kate Quote
Members CitizenKate Posted February 8, 2010 Author Members Report Posted February 8, 2010 Whew! Well, my idea worked. The new dye went on perfectly, and the board is now good as new again. It's just waiting for the new finish to dry... Kate Quote
Members RWB Posted February 8, 2010 Members Report Posted February 8, 2010 (edited) I use either a wax or lacquer finish (as shown in the samples). I add Tan-Kote to the antique. Now I'm curious, Ross... do you normally put your dye on over your sealer? Kate No. Not normally. There have just been a few occasions that I've had to touch something up after my antique and top coat are dry. Like I said the dye will soak through Neat-lac, but it takes some time. Again, out of curiosity, how do you charge for a redo like that? Is it based solely on time or do you have a set price. Ross Edited February 8, 2010 by RWB Quote Ross Brunk www.nrcowboygear.com
Members CitizenKate Posted February 8, 2010 Author Members Report Posted February 8, 2010 Again, out of curiosity, how do you charge for a redo like that? Is it based solely on time or do you have a set price. I have a "shop rate" I use to estimate the cost of everything I make, in addition to materials. I based the fee on the amount of time I think it will take, times the shop rate, plus I factored in a little more for all the tape, cotton balls, acetone, denatured alcohol, and about 36mL of dye I used on the job. On the materials, I don't know the exact amount of each I used, not worth the trouble to actually measure and track them, since they are just expensed anyway... just took a wild guess. LOL Kate Quote
Contributing Member ClayB Posted February 8, 2010 Contributing Member Report Posted February 8, 2010 That turned out great Kate! Quote ClayB Badlands Leather Art blog Badlands Leather Art Website
