Hello everyone,
I figured I might as well post a quick how-to on how I antique brass hardware. Not sure if anyone is interested, but it can't hurt, right? This is how I turned this:
Into this (forgive the crappy photography):
Here are my steps:
Scrub the surface of the hardware with steel wool until it has a dull shine
Pour vinegar into a container--enough to cover the bottom
Suspend the hardware above the vinegar (I tied string to the clips and taped the string to the outside of the container)
Cover the container with plastic wrap
Let sit as a blotchy, dark patina develops
When you have reached a patina you like, take the hardware out of the container and dry it off
Place hardware on an electric heat source (I used my electric stove on a medium setting) until it begins to darken
Remove hardware from heat (use pliers) and quench in mineral oil
Clean the oil off the hardware
That should give you a nice, somewhat uneven patina, which you can then buff with steel wool in spots that you want to shine like they have some wear. For my Apocalyptic Survivor style hardware, I usually add a bit of a melted texture by smearing wood glue on the surface of the hardware and then heating it over an open flame until it ceases to bubble.
~Noah
Website: Wasteland Leatherwork
Collaboration Projects: The Wasteland Crow Project
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
Now how did you know I was about to ask that question?
Many thanks, Noah. Useful info and very timely!
Ray
"Some mornings, it's just not worth chewing through the leather straps"
Ray Hatley
www.barefootleather.co.uk
That is fantastic! Thanks for the post on this. I've been wondering how to go about getting a nice used look on some hardware. Do you think the same process would work on shiny nickle plated stuff? I am going to have to experiment.
Cheers,
Andy
Thanks Noah,
I've been wondering how to do that too.
Moe
What you focus on determines your reality.
Some Jedi guy.
Noah, how long does this process take? Especially the hanging over vinegar part?
Thanks, Tom
Ray
I'm psychic? Haha, I'm glad I could be of assistance!
Cheers,
Andy
Well, I would be careful with anything plated--I did this to a buckle last night that was supposedly brass, but apparently it was actually a brass-plated pewter alloy of some kind because it started to melt on my stove and it's ruined now.
Thanks Noah,
Moe
You're welcome!
Thanks, Tom
It depends on how blotchy and dark you want it to look, but those clips spent approximately an hour to an hour and a half over the vinegar--just hang them up and go out to eat :)
~Noah
Hello everyone,
Here are my steps:
~Noah
Quite a few years ago I used to renovate old furiture and to antique new brass fittings used ammonia.
You just need to expose the fitting to ammonia gas so a small cup of ammonia and a plastic bag to form a tent does the trick.
Dosn't give the almost black finnish you got with vinegar but gives the brass a nice patina.
I've seen a few knife fittings that have been tarnished with ammonia, but I don't like the idea of having that particular chemical in my apartment, so I sought out a more lung-friendly method. The ammonia does give a nice patina, though.
~Noah
