Members NewYorkerInSydney Posted April 20, 2010 Members Report Posted April 20, 2010 Hi all, When you dip a piece of leather (a wrist cuff in my case) into leather oil dye and pull it out to hang dry, I notice that a lot of the dye then pools around the end of the cuff and drips off and sometimes just stays there which makes that end part of the cuff much darker. How can I eliminate this after dipping in dye? Also, sometimes I notice as it is all dripping down the dye streaks. How can I eliminate that? I am using plain veg tanned leather with leather oil dye and the leather is not wet before hand as it looks quite terrible if I wet it first. I just dip the dry leather into the oil dye (Fiebings). Thank you much, Sydney girl Quote
MADMAX22 Posted April 20, 2010 Report Posted April 20, 2010 I would ask Lobo, he hangs out in the holster section primarily and I think he dip dyes all his holsters. Would be the first person I ask. Quote
electrathon Posted April 20, 2010 Report Posted April 20, 2010 When you pull the piece out of the dip, "blot" the surface off with a soft rag. Then hang or lay it down to dry. Aaron Quote
Contributing Member UKRay Posted April 20, 2010 Contributing Member Report Posted April 20, 2010 You might want to try mixing your dye with neatsfoot oil. It makes it less 'dense' and less likely to give you a hard time. You may need to dip a couple of times to get the required colour but, IMHO, the finish is worth the effort. Ray Quote "Some mornings, it's just not worth chewing through the leather straps" Ray Hatley www.barefootleather.co.uk
Members Dwight Posted April 21, 2010 Members Report Posted April 21, 2010 Some I dip dye, . . . some I don't, . . . those I do, . . . get a good shaking before I hang them up to dry. You also may be leaving it in the dye too long, . . . pardon the pun, . . . but "dip", . . . "don't drown". Leaving it in the dye more than long enough for it to change color will sometimes produce a pooling at the lower end of the item. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
