Members MikeCahill Posted July 21, 2010 Members Report Posted July 21, 2010 I look at the superb hand stitching on this site, and then at my own sorry examples, how do you keep stitching clean? I wash my hands, use beeswax to seal and lubricate the thread but after two or three inches the thread is starting to get grubby, after 5 inches it looks like I've been kicking it around the shop any suggestions ? Quote
Members lbraider Posted July 24, 2010 Members Report Posted July 24, 2010 I dont do a lot of stitching but I like to use an antique stain on tooling leather. It looks great and hides a multitude of sins. I'll be watching here cause I want to know too. Quote Every one I meet is in some way superior; They know something that I don't and in that I can learn from them. An open mind leaves a chance for someone to drop a worthwhile thought in it.
Members Romey Posted August 14, 2010 Members Report Posted August 14, 2010 A very very clean work area and making sure my hands arent dirty. Keeping nice white stitching is a struggle Quote Romey Cowboy inc highcountryknives
Members katsass Posted August 14, 2010 Members Report Posted August 14, 2010 I look at the superb hand stitching on this site, and then at my own sorry examples, how do you keep stitching clean? I wash my hands, use beeswax to seal and lubricate the thread but after two or three inches the thread is starting to get grubby, after 5 inches it looks like I've been kicking it around the shop any suggestions ? Well, all I can think of is that possibly your leather wasn't totally dry after dying. In some areas of the Country it can take up to 24 hours to completely dry. I always dye my leather prior to assembly, allow it to dry overnight, then assemble, glue as necessary and then stitch. I then burnish my edges, oil lightly, dry. and then apply the finish. Maybe a picture would help us give you a hand. Mike Quote NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!! At my age I find that I can live without sex..........but not without my glasses. Being old has an advantage.......nobody expects me to do anything in a hurry.
Members steveh Posted August 14, 2010 Members Report Posted August 14, 2010 To much wax can cause the stitch to look dirty. Try burnishing the thread with a canvas cloth to heat the wax deep into the thread fibers, this will remove excessive wax on the thread. See if that helps. Steve Quote
Members lbraider Posted August 18, 2010 Members Report Posted August 18, 2010 Very good ideas. Thank you all. I just bought the stiching book and I'm going to start stitching with my braids. Quote Every one I meet is in some way superior; They know something that I don't and in that I can learn from them. An open mind leaves a chance for someone to drop a worthwhile thought in it.
terrymac Posted August 18, 2010 Report Posted August 18, 2010 Mike, Something I have learned the hard way is not cut your stitching groove until after you have dyed or antiqied. The thread completely fills the groove so you don't see the natural underneath. I then finish with Neat Lac after all is done. Terry Quote
Members Rawhide Posted August 18, 2010 Members Report Posted August 18, 2010 Here's what I found...The thread that most people use (usually from Tandy), is the culprit. For one thing the thread has WAY too much wax on it (which you can remove with brown paper bag). What you are seeing with the clean stitching are usually Linen cord. When pulling, the thread stretches, and it tends to look dirty. When you pull the linen, it doesn't stretch, so therefore it doesn't look dirty. Marlon Quote Marlon
terrymac Posted August 19, 2010 Report Posted August 19, 2010 Here's what I found...The thread that most people use (usually from Tandy), is the culprit. For one thing the thread has WAY too much wax on it (which you can remove with brown paper bag). What you are seeing with the clean stitching are usually Linen cord. When pulling, the thread stretches, and it tends to look dirty. When you pull the linen, it doesn't stretch, so therefore it doesn't look dirty. Marlon Marlon, How does linen stack against nylon in terms of strength. I am one of those using Tandy nylon, primarily because once I get it stitched, it isn't going anywhere. I understand what you are saying about the stretching and it makes sense. Is the linen comparable in diameters, or do you need diferent awls and needles? Thanks for the help. Terry Quote
Members js5972 Posted August 19, 2010 Members Report Posted August 19, 2010 It is not always practical, but I use Deglazer to clean up the stitching when I can. Quote John Schmitz New to Oklahoma City via Baja Arizona
Members Rawhide Posted August 19, 2010 Members Report Posted August 19, 2010 Marlon, How does linen stack against nylon in terms of strength. I am one of those using Tandy nylon, primarily because once I get it stitched, it isn't going anywhere. I understand what you are saying about the stretching and it makes sense. Is the linen comparable in diameters, or do you need diferent awls and needles? Thanks for the help. Terry I've never used nylon, (I don't think I have anyway.) I can tell you that I have had holes fail before the cord, but over years of hard wear...think saddles and such, linen has been known for dry rotting. I'm pretty sure nylon won't rot on you, but for belts, purses, gun rigs etc.., I would use the linen to get the pretty white stitch. As far as needles and awls, nothing special is required, and the diameters are comparable. For most stitching applications 3-cord, and 5 cord are probably the most used. The only other consideration is the twist direction. There is a school of thought about using left (S) or right (Z) twist cord. I use left with no issues. There is a discussion thread on it here somewhere. I bought left for one reason only, and that is because it can be used in a sewing machine. I've never done so, but that was the reason. Marlon Quote Marlon
Members BAD HIDE Posted November 14, 2010 Members Report Posted November 14, 2010 Ok, this is kindof a follow up question. After getting those white stitches in there, how do you keep them that way? I've noticed on things I've carried for only a few months that the stitching got a little fuzzy and dirty in wear areas. When I started, I did all my finishing before assembly, and then nothing on top of that. I've been experimenting with my materials and order in which I do things to see if I can protect my stitching better. I've tried doing my dyeing and 1 coat of acrylic finish before assembly, 2 coats after to go over the stitching and seal it, but wax + water doesn't mix, so I'm doubtful it's really doing anything more than sealing the holes and not the thread. I've also started trying clear-lac in the same 1-2 coat manner, but I've noticed a little dye bleeding into the stitches, especially if I apply with rag or brush - which is usually how I apply finishes. So what's the professional's method to long lasting white threads? Quote Badhide.com
Members Rawhide Posted November 15, 2010 Members Report Posted November 15, 2010 Don't know if this is the proper method or not, but here's how I do it: I completely finish the work, dye, resist, stain, topcoat, etc... all of this is done first. Then I use a channeler (stitch groover), to remove a thread of leather from the workpiece. Then I stitch in this groove. The stitches then sit in this groove, below the surface of the leather to prevent wear and tear. I haven't had much "hard" use of my items so I haven't had them get dirty. I do wax them pretty good, but that's all I do. Marlon Quote Marlon
Members unicornleather Posted November 15, 2010 Members Report Posted November 15, 2010 Make sure the ends of the clam you are using are clean, if they are covered in leather they can get grubby and make the leather and stitching dirty. The beeswax on the threads will draw out any dirt, fat and possibly dye from the leather you are stitching and deposit it on the thread too. Use short lengths of thread instead of one long piece to keep it from starting to get grubby and change it often for a new piece. I use a clean white cotton cloth over the ends of my clam and clamp my work to be stitched inside it if I am using white or yellow threads. We used to cheat when stitching in Cordwainers (Saddlery college) on work that was going to be marked for our course work and if we got dirty white threads we'd use a little bit of Tippex correcting fluid on the thread, it made it look like new and we got better marks! Oz Quote
Members Dwight Posted November 16, 2010 Members Report Posted November 16, 2010 Mike, . . . you didn't say what type tools you are using, . . . or at least I didn't see it. If you are using (what I call a sail needle) the needle kit that has a wooden handle and the little spool of thread, ........ that is the culprit was my experience. I pitched the spool, . . . use a cut piece of thread that I measure out at least 3 times the length of my stitching, . . . put it through my awl hole, . . . pull half to the other side, . . . and go from there. With the spool in place, I was keeping the working piece of thread short, . . . and it got dirty quick. I figured it out when the back side was really clean, . . . and the front looked groady and grubby. Anyway, . . . hope this helps. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
