Hi all, Looking for a supplier of pre- sharpened die steel thanks for the help.
Try a google search for "helmold steel rule dies" see if that may help you.
steve
thanks will give it a try
Check with your local steel supplier and ask for "Steel rule die stock." It comes pre sharpened (Well, mostly, like any knife blade) and in various sizes/lengths. You can use this to form just about any shape die. Then mount on a board or weld in bracing to make clicker dies.
Dave T.
How much and what size are you looking for? In most cases if you want 1.25" it comes in 220' rolls and there are several places. the smaller heights like 3/4" can be found in 3' strips but create alot of waste. Depending on what size and how much I could provide some.
Dink
prorodeooutfit@aol.com
