Does anyone out there know where I can find a Craftool Masonic emblem stamp or something similar? I have a project in the works and would really like to have or have access to one. I have found two on Ebay but they are out of my price range for just the one project.
Thanks
Donnie
Did you ever find one of these? I may have one that I could loan you but I would need it back
Tom
Thanks
Donnie
Tom
Thanks for the offer Tom, I ended up doing the emblem by hand, Whew!
Glad it worked out for you
Tom
Thanks
Donnie
I just had a custom stamp made by Phillips Engraving Co.,
Contact:Alex Porterfieldleatherstamps@phillipsengraving.comwww.phillipsengraving.comToll Free: 1-888-369-6906
They just need clean black and white images, preferably in digital format.
  • 1 year later...
I know this is an old thread and apologize for showing up late, but could you give me an idea of the expense? Thanks.
Depending on what size you need, duckcreektraders makes 2 different sizes of an emboss plate with the Masonic Emblem.
duckcreektraders has an auction site on ebay and they rotate their emboss items on a regular basis. The Masonic Emblem is not up for auction
right now but you can also go to their website at bunkhousetools.com and contact them about buying any items there... tiptoncompany@gmail.com
post-15330-082539400 1337366850_thumb.jpMasonic & Shriner Emboss Plates Pr 1 1/8" & 1"Tall
This is what it says about this plate
The Masonic plate is 1 1/8" tall and the Shriner is 1" tall and are made of a high impact fiberglass reinforced polyurethane. We originally started making these plates to use on short runs where we only needed a few hundred impressions BUT we soon discovered that they were outlasting any of the plates made of printers metal and have much greater detail than most cast metal plates.
The samples were made using a 12 ton hydraulic shop press which should be sufficient for plates of this size or even slightly larger.
These plates are not hammer stamps and should be pressed in using a small press such as the arbor press available from such places as Harbor Freight for under $50 or you could use the Tandy/Leather Factory Imprinter. If you're careful and use a light pressure you could use a hydraulic press, clicker press, or a shop press like we do but the pressure plate should cover the entire top of the plate or if you are using a ram press a heavy piece of flat steel sufficient to cover the entire top of the emboss plate will be necessary.
For more information about the polyurethane embossing plates and their full warranty please visit our website bunkhousetools.com
and
post-15330-089668600 1337366932_thumb.jpMasonic Emblem Leather Emboss Plate 2 3/8"x2 3/8"
This plate measures 2 3/8" by 2 3/8" and is made of a high impact fiberglass reinforced polyurethane. We originally started making these plates to use on short runs where we only needed a few hundred impressions BUT we soon discovered that they were outlasting any of the plates made of printers metal and have much greater detail than most cast metal plates.
This plate is not a hammer stamp and should be pressed in using a hydraulic press, clicker press, or a shop press like we do but the pressure plate should cover the entire top of the plate or if you are using a ram press a heavy piece of flat steel sufficient to cover the entire top of the emboss plate will be necessary.
I Hope this helps :thumbsup:
