CowboyBob Posted October 28, 2010 Report Posted October 28, 2010 Ok, here's something else to check,if you put the needle bar all the way down & hit the reverse lever does the feed dog& needlebar move or stay still? Bob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members QDaddy Posted October 29, 2010 Author Members Report Posted October 29, 2010 Ok, here's something else to check,if you put the needle bar all the way down & hit the reverse lever does the feed dog& needlebar move or stay still? Bob Well, well... I think you are on to something. They move less than a 1/16" even at 8 stitch setting. I distinctly remember that they moved more than that in the past. Quote
CowboyBob Posted October 29, 2010 Report Posted October 29, 2010 As long as your sure the needlebar is all the way down & when you hit rev & let off the handle the LESS it moves the better,for the achine to sew & feed the best it shouldn't ove at all. Also the partr we call the bobbincase position fingeer(the part that keeps the bobbincase base from spinning) seems to work best when it's pushed back towards the back of the machine. One last thing: are you sure the hook is timed correctly?if it is too slow inotherwords if you have to much rise on the needlebar when the point of the hook comes around it'll like to jam up like it's doing. Bob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members QDaddy Posted October 30, 2010 Author Members Report Posted October 30, 2010 My initial observation of the "reverse foot movement" was incorrect. When I adjusted the stitch length from 3 (executed 3 cycles) then to 8 (executed 3 cycles) then back to 4, I bottomed out the needle completely and hit the reverse. Wow... that needle moved the entire length of the basket opening. In fact, the reverse wouldn't fully execute because the needle pushed against the end of the opening. Is that an indication of a timing issue, or have I knocked something out of whack? Thanks again Bob and Wizcraft. Quote
Moderator Wizcrafts Posted October 30, 2010 Moderator Report Posted October 30, 2010 My initial observation of the "reverse foot movement" was incorrect. When I adjusted the stitch length from 3 (executed 3 cycles) then to 8 (executed 3 cycles) then back to 4, I bottomed out the needle completely and hit the reverse. Wow... that needle moved the entire length of the basket opening. In fact, the reverse wouldn't fully execute because the needle pushed against the end of the opening. Is that an indication of a timing issue, or have I knocked something out of whack? Thanks again Bob and Wizcraft. Tis time to pack up the head and ship it to an industrial sewing machine repair depot. Where are you located? Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members QDaddy Posted October 31, 2010 Author Members Report Posted October 31, 2010 Great... I can't even afford to ship it anywhere, much less pay for repair. Any thoughts on what the problem is? Quote
Members Gregg From Keystone Sewing Posted October 31, 2010 Members Report Posted October 31, 2010 Great... I can't even afford to ship it anywhere, much less pay for repair. Any thoughts on what the problem is? My thoughts, after reading this thread, with a fresh set of eyes? I think you have two people who have handle on things doing thier best to assit you, and they both feel at this point someone who is qualified needs to have a look at the machine. A lot of sewing machine repiar involves see, touch, and feel in order to be able to properly repiar your machine. Good luck! Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
