Members treybecca Posted December 3, 2010 Members Report Posted December 3, 2010 What is the best way to get Vegatable tanned leather white? Thank you for your advice! Quote
Members Nutty Saddler Posted December 3, 2010 Members Report Posted December 3, 2010 Very carefully. Do the usual prep - de-glaze , dye prep as required - I get both these from Fiebings . I then thin the white dye and spray it on - In my experiance it is better to apply a thin coat and let it dry then spray again and repeat until the required coverage is obtained . You may fine that the acrylic dye is better and easier to use , and that it gives a better finish - again I've got mine from Fiebings . Good luck with this as I've found the white the worst colour to work with as is shows up every mark, smudge , stray fleck etc - also as it is either an acrylic or a suspension dye the leather doesn't absorb it so the surface you are applying it to needs to be extra carefully prepared . Just my experiance is all - others may have had better results Quote
Members Dwight Posted December 3, 2010 Members Report Posted December 3, 2010 For what little white leather I have done, . . . I just buy white leather. Saves the mess and what little hair I still have. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
