Well, got my Saddle Tan all cut. Here's a photo of what I ended up with.
Conversions;
  • 24,688.8 MM
  • 2,468.88 CM
  • 24.6888 M
  • 0.0247 KM
  • 972 IN
  • 81 FT
  • 0.0153 MI
The cutting of the hide would've only taken me about 20mins. But the phone kept ringing because I am on call until Saturday. Sometimes, I wish I could retire and just leather braid for a living. Wont get rich. But I'm not in it to get rich anyway. LOL...
Brian...
Best Regards,
Brian Kidd
Well done Brian
I bet you are stoked with your hides, but now you have cut your lace, after stretching what is the finished width going to be of your cut lace ?
When I cut lace for a bosal, I might be looking for 3mm finished lace for a nose button, and 4.5mm to cover the rawhide core , so i will cut a 25mm strip , after stretching i will cut that strip into my strands ,getting 4 strands at 4mm wide to resize and bevelle so i have enough 3mm strands for my nose button , with the rest of the 25mm strip i will cut 3 strings at 5mm , resize and bevel to cover the core with a 12 or 16 plait ,
with the bike seat shape peice of leather left over i will get my tandy lace cutter and get a heap of lace 5 mm wide that i will resize for the heel knot and spanish ring knots, I also will cut the hind legs and tail off first so i can cover my stock whip handles out of them, most of my hides come in at around the 6.4 or 6.6 dm mark
It took me awhile to work out but this works for me and with what i do and I am sure you have got your hides all worked out aswell , best of luck mate and happy braiding !!
Cheers
Bevan
http://www.bwrwhips.com
I am thinking 1/8 for a project I have to finish. That's a lot of string in that tub. The rest, after the project is done, I will probably make some key fobs and necklaces and bracelets and so on.
The stretching is just about like any other lace. Just more of it and a little wider. Mostly it's just stretching it to straighten it enough to cut it down, and then stretching some more as you go.
Brian...
Best Regards,
Brian Kidd
Rob,
This is how I stretch mine. Fast forward to 9:13 in the video
Marlon
Well done Brian
Cheers
Bevan
Thanks Bevan. I still have along ways to go to get my lace as sharp looking as yours though. But that will improve once I get my cutter inserts. Then, it's on. I wont be coming out my dungeon for a while. LOL...
Brian...
Best Regards,
Brian Kidd
Howdy, I got my two hides today. COUGH COUGH oh gosh wonder if I sould call into work sick I might be coming down with Roo fever. hehehe as knothead would say I'm so Giddy"
Let me council with the board to see if you should play hooky.
Begin meeting,
:gathering:
End Meeting.
The counsel has decided.
:rockon:
:dance: WooHoo!!! Of course this is just a biased opinion. LOL...
B...
:crazy:
Best Regards,
Brian Kidd
I'm scared to death to cut my hides. I cut around the edges to make it as round as possible and was to scared to cut it so I took the outer pieces to pratice on. The I'm guessing leg area was a pretty good size piece so I gave cutting that a try and I did terrible. I didn't get a single piece of lace made out of it. Don't know if I didn't cut it wide enough or what. when I took the piece then tried to streatch it the best I could, I then tried to cut it down to where it would be a straight piece of lace and nope I couldn't get a single piece to look good. How wide should my first cut be?? And out of that first cut do you only get one piece of lace?? If you cut around in one circle 1 inch wide do you only get 1 piece of lace 1/8 inch wide???? with me totally striking out with that first effort I'm scared to death I'm going to ruin my two hides and waste 200.00. HEHE the 2 flopped cowhides at $30.00 doesn't seem to bad when I'm now looking at flopping up $200.00 worth of hide.
acox4t4: Now you are scaring me! I want to try and cut my own strings in a few months. What are you using to cut?
KnotHead: If you use the aussie strander to cut, how do you bevel? Can you do both with that tool?
Thanks!
Edited by 8KCAB
