Could someone please explain to me the relationship between the length of my stitches and the thickness of material to be sewed. I am a sewing machine virgin. Have never touched one until last Friday when I recieved a brand new Cowboy 3500.Thye machine is similiar if not identical to a Artisan 3000 and Cobra class 3. I have stitched and stitched scrap leather for the past few days trying to figure this thing out. My first project will be of alligator. I can't afford to muff it up. My project is a wild buch rig for cowboy action shooting. It consist of 7/8, 9/10, and 12/13 oz skirting. The holster will be close to a 3/4" welt. The stitching looks exactly how I want on the lighter leather, but when I switch to the thick stuff ( 1/2" or more) I get little teeny stitches. Do I have to adjust this thing every time I switch leather thickness. Is there a tutorial on this somewhere?
Thanks!
Where is the dealer you bought your 3500 from? He will setup the machine for you. These are needle feed machines and should not have a problem feeding, unless the presser foot pressure is too light and the material is pulling back because of lack of pressure to hold it. Your dealer can help you with this.
Art
Thanks!
The machine was set up to sew out of the box exactly as I asked it to be. I have been in contact with Bob Kovar at Toledo sewing and he has been very accomodating. As I stated in my post, I am newer than new when it comes to sewing machines. I did not want to continually pester Bob with a barage of questions as I learn the machine. I thought maybe I could gain some insight here on the forum.
That's what Bob is there for. He should get to know you on a first name basis. Being no form of keyboard daemons, it will take a long time to convey what can be done on the phone in a few minutes. Call him.
Art
Thanks!
I also just bought the CB3500 from Bob ( 3 weeks ago), and he's been very helpful.......but what you're dealing with, you shouldn't even have to call him....there's a manual right?
In it it shows you how to lengthen/shorten the stitch. Just turn the knob shown in this picture.
The relationship between the thickness of the leather you are stitching and the length of the stitch, is something out of "stitching 101", or to be more exact, Al Stohlman's " The Art of Hand Sewing Leather".
From that I learned that projects up to 1/4" thick look best stitched at 6 stitches per inch.......3/8" thickness, 5 SPI.......more than that, including your 1/2 or 3/4" thickness, 4 SPI......it's been a good rule of thumb for me when hand-stitching, and it's no different on the 3500.
I've made the adjustment several times already and it's really simple.....turn the knob, do a test on scraps that are the same thickness as you'll be stitching, adjust til you like the length of the stitch.
I'm by far no expert, but we're getting along (3500 and I ) very well, if you get stuck and Bob can't be reached, give me a hollar.
Edited by Rayban
Rayban
www.rgleather.net
Rayban,
I believe the question here is why are the stitches not the same length on thicker leather as on thin WITHOUT changeing the setting on the lever. I think they should be, so that when you sew from thick to thin or visa versa such as where you have leather overlaped the stiches stay the same length.
Catskin,
You are correct. I simply wanted to know why when I switch from one weight to the other does the machine sew different stitch lengths. Bob was very helpful in fiquring out the solution. As Rayban stated, I have to adjust the lever when I switch from one weight to another. I'm just trying to figure out why it does it. As new as I am to machines, I was under the assumption it would sew the same stitch length no matter what weight it was presented until I changed the setting myself.
That's strange. My Highlead sews 6 to the inch (according to my Campbell Bosworth gauge) and it doesn't seem to matter what I put in there. I don't think I have changed the stitch length lever except to go forward and reverse. Any chance your bottom stitch is hanging up on the needle (feed dog) slot in the needle plate? Maybe you could up your presser foot pressure a bit, and hold your threads tight till they get past the slot.
Art
Catskin,
As Art stated other machines DO NOT make a different stitch length when you change thickness of leather under the foot. My OLD Adler 20-2 does not and it has just bottom feed and jump foot. I have a new 4500 Cowboy so I know what they are like.
I thought the new machines would be at least as good as the OLD ones as far as consistant stitch length is concerned. This might have to do with the linkages in the compound feed. I do hope someone will get on here and explain why this happens.
Catskin,
We need...
The Wiz !!!!!!
Rayban
www.rgleather.net
