Moderator Wizcrafts Posted September 17, 2017 Moderator Report Posted September 17, 2017 I usually buy Organ brand titanium coated, in walking foot System 135x16 and 17, on eBay. But, if you have an industrial sewing machine dealer nearby, call them and ask if they have or can get titanium coated needles in 135x16, or 29x4. Those are leather point systems. Round points would be systems 29x3 and 135x17. They really do make a big difference! Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Ornito Posted September 17, 2017 Members Report Posted September 17, 2017 Thanks a lot! Quote
Members Ornito Posted September 18, 2017 Members Report Posted September 18, 2017 16 hours ago, Wizcrafts said: I usually buy Organ brand titanium coated, in walking foot System 135x16 and 17, on eBay. But, if you have an industrial sewing machine dealer nearby, call them and ask if they have or can get titanium coated needles in 135x16, or 29x4. Those are leather point systems. Round points would be systems 29x3 and 135x17. They really do make a big difference! Wizard, Just fyi I contacted the European Distributor, here is the answer: "thanks a lot for your inquiry. But DIX4LR 120/19 Titanium coated LP coating is not in ORGAN production line. Kind regards Rudolf Rütters" So, do you have more suggestion to avoid missing stitches caused by glued leather layers ? (Using tape or different glue, or an alternative method ?) thanks again for you help. Quote
Moderator Wizcrafts Posted September 18, 2017 Moderator Report Posted September 18, 2017 6 hours ago, Ornito said: Wizard, Just fyi I contacted the European Distributor, here is the answer: "thanks a lot for your inquiry. But DIX4LR 120/19 Titanium coated LP coating is not in ORGAN production line. Kind regards Rudolf Rütters" So, do you have more suggestion to avoid missing stitches caused by glued leather layers ? (Using tape or different glue, or an alternative method ?) thanks again for you help. Here are the System 135x16 needles I have been buying from an eBay seller. They are Organ brand and most certainly titanium coated and leather point. They fit the 29k patchers perfectly. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Ornito Posted September 18, 2017 Members Report Posted September 18, 2017 47 minutes ago, Wizcrafts said: Here are the System 135x16 needles I have been buying from an eBay seller. They are Organ brand and most certainly titanium coated and leather point. They fit the 29k patchers perfectly. Thank you !!! Quote
Members Marcremb Posted June 6, 2022 Members Report Posted June 6, 2022 On 4/12/2011 at 10:18 PM, Wizcrafts said: If the motion feed crank has a worn down feed puck, you can braze bronze onto it, then shape it with a file, then buff it to a polished finish. If you take your time and get the clearance and ends shaped just loose enough to allow the crank to turn 360 degrees, you will get the maximum stitch length possible (~5/inch). I did this to two Singer patchers and both gave 5 stitches per inch after the bronze build up job. Hello Wiz On 4/12/2011 at 10:18 PM, Wizcrafts said: If the motion feed crank has a worn down feed puck, you can braze bronze onto it, then shape it with a file, then buff it to a polished finish. If you take your time and get the clearance and ends shaped just loose enough to allow the crank to turn 360 degrees, you will get the maximum stitch length possible (~5/inch). I did this to two Singer patchers and both gave 5 stitches per inch after the bronze build up job. Hello Wiz (dont know your first name) My first name is Marc . I like your participation to the forum. You got a lot of experience their. Really appreciate it. About the Singer patcher stitch length problem, i have the same issue on my 29K171. You wrote bronze build up. Is it possible please to see a picture of which part you've done it? Thanks Quote
Moderator Wizcrafts Posted June 7, 2022 Moderator Report Posted June 7, 2022 10 hours ago, Marcremb said: Is it possible please to see a picture of which part you've done it? This is the feed motion crank I am referring to: https://www.ebay.com/itm/162537988829 Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
