Can someone tell me what this machine is. Found it locally and am wondering if it is worth picking up and working on this winter.
Thanks.
Thanks.
This looks like a 97 Class Singer. Not many were manufactured and parts could be hard to come by. Bob (sewmun) could give you a bit of advice on that I think. For some info the Smithsonian has the following: http://www.sil.si.ed...ages/image1.htm
I am a collector of old machines. Usually that sort of monster, if it is under $300 is best to grab and worry about the details later.
Those things can change hands for big bucks.
Darren Brosowski
Corey, yes,it's a 97-10 & parts will be hard to find for it & you'll even have a hard getting the correct needles for it as they haven't been made for years,I found 500 of them a couple of yrs ago but they're all gone.This machine will sew you to 1" thick with the correct needle,you can lower the needlebar down & use a 794 needle that is readily available but you be limited to sewing 1/2" thick with it.
Good Luck,
Bob
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Good Luck,
Bob
Hi Bob,
Do you know the dimensions of the needle for the 97-10? I have a couple of contacts with old stock here in Australia so if you know the system I may be able to find something.
On a similar note - I have a needle in a hand crank machine from China that is about 1/4" longer than the Singer 7 needle. Any idea what this might be? It is a new production needle but the machine supplier is a bit vague.
Darren Brosowski
sort of found an answer. The 97-4 needle is 2 3/4" long, same as the needle for the '7'.
So I suppose the next question is why doesn't the Singer 7 needle fit? Can the needle clamp be modified?
Darren Brosowski
