Hi all, does anyone have templates or construction details for a cigar case. I would like to make one that is two peice and holds around 3 cigars. I have seen a couple but no details on how to make/fit/form. I have made a few holsters but this style of project is new to me. Thanks in advance for any help or suggestions.
Carl
Carl
There's a pattern in Vol 1. of Stohlamn's Mking Leather Cases.
Thank you, I will have to try to find it. Carl
There was also an article and patterns in an issue of the LCJ. You might check their data base
Blake
To separate individual compartments for cigars, you might try a U shaped yoke to create creased sections, and "clip" it over the case with dowels as fillers for the space.
ie. You would need two U shaped "clips" to creat three compartments.
