Phatdaddy Posted August 31, 2011 Report Posted August 31, 2011 I will more than likely be purchasing a maul from Beary in the very near future. There is only one concern, I have never used anything but the cheapies from Tandy (the ones with the yellow poly head) I do find them a little on the light side. I'll likely only be able to pick up one weight for now, but i'm unsure how to best decide on the weight. I only have Tandy as a resource and don't know of anyone else in my province that I could test out their mauls etc. Any suggestions? Thank you, Kevin Quote
KAYAK45 Posted August 31, 2011 Report Posted August 31, 2011 Hi Kevin, Kevin here! Great choice in maker, by the way. I bought beary's first maul and just received my second. I went with a Bearman recommendation of 18 Oz on my first maul, as the over all general best weight. Later, and got it about a week ago, I ordered a 24 Oz. Both are great mauls and I wouldn't change a thing on them. The 18 is best for fine tooling, no doubt, the 24 a little heavy for that. But the 24 is nice to have for some larger...say basketweave that I want one hit, no shadow. Hope this helps your decision on size. Anything you get will be WAAAYYY better than the polymer from Tandy!!! Good Hunting, Kevin Quote
King's X Posted August 31, 2011 Report Posted August 31, 2011 I use a 14oz from Bearman maul for light leather tooling and an 18oz maul for general tooling. For my baskets and geometrics, I use a 24oz Stohlman maul. For heavier tooling and makers mark, I use a Stohlman 3lb. I would definitely recommend an 18oz as a starter. With either Beary or papa bear.....you cannot go wrong. Quote
Members Spinner Posted August 31, 2011 Members Report Posted August 31, 2011 I agree on the 18oz. I have the Stohlman 1lb. maul and like it but within a few months it started to feel light on projects with basketweave and other stamps needing a good "whack". That size is great for medium to fine tooling but the extra weight would be nice to have around. I'll be asking Beary for a 24 oz. here soon myself. Quote
gtwister09 Posted August 31, 2011 Report Posted August 31, 2011 Kevin, Here's some threads that have already discussed weights and such. Thread #1 Thread #2 Hope these give you some more information. Regards, Ben Quote
Phatdaddy Posted August 31, 2011 Author Report Posted August 31, 2011 Thank you all. Appreciate the guidance. Kevin Quote
Phatdaddy Posted August 31, 2011 Author Report Posted August 31, 2011 Is there a technical reason for a straight cylindrical or tapered head? Thanks again, Kevin Quote
Moderator bruce johnson Posted September 1, 2011 Moderator Report Posted September 1, 2011 Is there a technical reason for a straight cylindrical or tapered head? Thanks again, Kevin You don't have to lift you arm or shoulder as high to hit the stamp level. Quote
Members MHolzer Posted September 1, 2011 Members Report Posted September 1, 2011 I love my bearman mauls. Mine are 10oz and 17oz in bloodwood. Quote
Phatdaddy Posted September 1, 2011 Author Report Posted September 1, 2011 You don't have to lift you arm or shoulder as high to hit the stamp level. And that's with the tapered one I assume? Makes sense. Thank you Quote
Moderator bruce johnson Posted September 1, 2011 Moderator Report Posted September 1, 2011 Yes, with the tapered. It makes a big difference for me using anything over a 16 oz maul. Some of what I do are big pieces and I can't always reach the center if I rest my elbow and rock the maul. On my bigger baskets and block stamps I am faster and less fatigue to use heavier mauls and do one hit on the baskets or two hits on the blocks rocking the stamp one way and then the other. I can keep my elbow locked to my side and use my whole forearm with my wrist straight. Quote
