Members Suicide Posted November 24, 2011 Members Report Posted November 24, 2011 Hi everybody, I'd like to mark stitching holes on the deerskin to have even spacing and punch it later on. I tried to use overstitching wheel but on the deerskin marks are almost invisible and almost disappear after couple of minutes. Is there any other and more handy ways rather than mark holes on the pattern's paper and then trace them 1by1 with the marker? Any hints? Thanks in advance! Quote My leatherwork gallery
Members Leatherimages Posted November 24, 2011 Members Report Posted November 24, 2011 A silver ink pen is helpful here. Fisher Pens has them in their economy line. Use your over stitch whele and follow up with the silver pen. It can be erased from the leather. Make sure with a test first tho. Quote Back to the bench, Paul "When you finally get your wings, don't complain about the wind in your face."
Members Suicide Posted November 24, 2011 Author Members Report Posted November 24, 2011 Thanks, I'll give it a try. Quote My leatherwork gallery
Members Dwight Posted November 24, 2011 Members Report Posted November 24, 2011 You can also use a pair of dividers, . . . takes a while, . . . but they WILL BE evenly spaced if you do it correctly. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Billsotx Posted November 24, 2011 Report Posted November 24, 2011 (edited) Hi everybody, I'd like to mark stitching holes on the deerskin to have even spacing and punch it later on. I tried to use overstitching wheel but on the deerskin marks are almost invisible and almost disappear after couple of minutes. Is there any other and more handy ways rather than mark holes on the pattern's paper and then trace them 1by1 with the marker? Any hints? Thanks in advance! I like a very fine point red ink felt tip pen. You can even draw lines with red ink if you're going to dye your project, as the red ink will hide when the dye goes on. Test it on scrap if you're not sure. Edited November 24, 2011 by Billsotx Quote
nwolcott Posted December 24, 2011 Report Posted December 24, 2011 Use masking tape then use your overstitch wheel on the tape - it will leave holes in tape, stitch it up, peel off tape. Quote
