Members DSJackson Posted January 17, 2012 Members Report Posted January 17, 2012 I recently bought a side of 8-10oz strap grade latigo from Tandy and as I'm still so new at this I had a couple of questions. Item can be found at this link: http://www.tandyleatherfactory.ca/en-cad/search/searchresults/9056-05.aspx 1) It's vegtan latigo, I was wondering if vegtan latigo edges will burnish? 2) Can it be wetformed as tooling leather can be? 3) Would this be an adequate leather for a fixed blade knife sheath? Quote
Members McJeep Posted January 17, 2012 Members Report Posted January 17, 2012 (edited) I use this stuff fairly regular for bike gear and bridle repairs - still a newbie but offer the following 1) It's vegtan latigo, I was wondering if vegtan latigo edges will burnish? I've managed to burnish it to a certain extent and fiebings edge dye *seems* to work well - haven't had any bad results yet but I doubt it has soaked in much - time will tell 2) Can it be wetformed as tooling leather can be? Not in my experience - the deep oil prep of it means it won't soak up the moisture required, nor will it stay glued with contact cement - it'll stick well and long enough to anchor it for stitching but not long term 3) Would this be an adequate leather for a fixed blade knife sheath? Not if it needs to be formed (see above) but if it's a flat stitched sheath maybe - have no idea whether the chemicals in the oil treatment of it would harm the blade tho? It would certainly last a long time ;0) This is definitely a utilitarian leather, not a pretty leather ;0) Hope this helps Rob Edited January 17, 2012 by McJeep Quote "I gotta have more cowbell!" Cristopher Walken - SNL
rickybobby Posted January 18, 2012 Report Posted January 18, 2012 I recently bought a side of 8-10oz strap grade latigo from Tandy and as I'm still so new at this I had a couple of questions. Item can be found at this link: http://www.tandyleat...ts/9056-05.aspx 1) It's vegtan latigo, I was wondering if vegtan latigo edges will burnish? 2) Can it be wetformed as tooling leather can be? 3) Would this be an adequate leather for a fixed blade knife sheath? I use RM Williams conditioner all over the piece and burnish edges with canvas cloth. It leaves a pretty good edge. I have also used the Tandys new conditioner, it works pretty well too. I have not tried to wet form, as stated before by someone else I don't think it will stay because of oil content of the leather. It will make a durable knife sheath, if it is a fixed blade be sure and install a welt to protect the stitches. Quote Rick
Members JET4 Posted March 1, 2012 Members Report Posted March 1, 2012 I recently bought a side of 8-10oz strap grade latigo from Tandy and as I'm still so new at this I had a couple of questions. Item can be found at this link: http://www.tandyleat...ts/9056-05.aspx 1) It's vegtan latigo, I was wondering if vegtan latigo edges will burnish? 2) Can it be wetformed as tooling leather can be? 3) Would this be an adequate leather for a fixed blade knife sheath? I work with heavy latigo all the time. I edge and burnish all the edges with gum tragacanth. You can use either canvas or I most recently have been using a wood burnisher from Spinner on a dremel. If you do it right, you can get a slick, shiny edge. I am also trying some Wyo Quik Slik form Sheridan leather (check out the banner ads.....no website yet). I get the same to better results on latigo with it. Don't even bother with beeswax...it won't penetrate into the leather. No wet forming as it is pretty water resistant I would use a different leather. I'm not sure what the leather might do to a knife blade over time. The color of burgundy tends to run and bleed out if it gets wet....that might stain the wood on a handle. I use veg tan for sheaths. Quote Otis Leather Company
