Hy fellas, well i got the bug to buy a an old singer (due to budget) to do a few leather projects. Found a 111w100 dirt cheap. Found out the hard way that "W" doesn't necessarily mean walking foot :thumbsdown: But even without it, it feeds everything i do just fine so far. So on to the next gripe, apparently this machine only does a minimum of 6 stitches per inch :thumbsdown: Even if i manually set the drive eccentric set screw to its max. So my question... is there any known way to reduce the stitch length? Im hoping to get at least 4, that would be great. Although i hate to start another project, i have a lathe, mill,etc., so im not afraid to open it up. But if that's the case maybe ill just look for another head.
Although i don't want to break the bank either. I grabbed this one for $50 on craigslist, and found a worktable as well for $35 that i converted and cleaned up. I had a heavy duty 12 volt motor lying around, hooked it up to a PC power supply and regulated the voltage via an old dewalt VSR trigger that i retrofitted into a guitar hero drum pedal. So yeah, im a cheap ass. I have a whopping $100 into this so if i can get it do 4 stitches ill be in heaven!
AH, almost forgot, i promised free pics. Here she is all cleaned up. It was a mess but its all working great!..
Looks good,
If you open the upper plate & look to the left of the timing belt,you might have to turn the machine around so you can see the little screw,there SHOULD be 2 in there,take the 1st one marked BB on the diagram & turn CC in as far as it'll go,reinstall lock screw BB & it will be as long as it can be.We can get a teflon foot for it that will reduce the drag of the steel foot or you could even just glue some teflon on the bottom of the feet to help.
Bob
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Yeah that was the first thing i tried. I set it to its max travel but it only will give me 6 stitches. I was thinking of somthing more drastic. Like machining the drive eccentric plate to increase its travel. Are there any other 111w-XXX machines that do 3 or 4 stitches per inch? I thought there were. Is stitch length adjusted the same on those?
Hi Black2. The feed mechanism might be "gummed up", or is not moving to it's maximum/minimum capabilities due to lack of oil or lubricants over the years. Try some WD 40 on every component of the machine while running it at a higher speed. This will start to loosen up the moving parts, linkage's and eccentrics. After running the machine for 10-15 minutes, oil it everywhere. Be liberal with the Wd 40, and the oil. Of course you will have to clean the machine after doing this. This may help. Good luck. Steve
Thank You
Steve Tayrien
Leather Machine Co., Inc.
2141 E. Philadelphia St. Unit "U"
Ontario, California 91761
1-866-962-9880
http://www.leathermachineco.com
cobra@leathermachineco.com
I looked it up & that's all your going to get.You can see the chart what other models get for stitch length.
Bob
Edited by sewmun
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Steve has a good idea. These machines do get gummed-up over time. With the WD-40, stay off the screws as much as possible, but it won't be a problem if you don't. Also stay away from the belt with the WD-40. I have never thought of WD-40 as a lubricant, but more as a cleaner. Spray it on, run it in, even spray while running, then wipe it off. Repeat as necessary. Oil pretty well afterward to force any WD out.
One thing you might want to know. Singer used some of the damnedest thread pitches in their long production life. They must have owned a tap and die factory. I've never had to replace a screw on a 111, so I am not sure if they are the exception. Good repair shops like Bob, Steve, or a local old timer usually keep a box of old screws for their own use when they lose or bugger one up; keep that in mind and get a magnetic dish for screws. Singer bearings on the shafts are often hand lapped to the shaft, if you don't know what that means, don't take the shafts out, if you are going to paint, just leave the shafts in and mask them off. I have seen some way cool paint jobs over the years, but I can tell you that a black 222 will sell for more than a pink one.
Art
Bob
Bob;
You posted the scan upside down!
Posted IMHO, by Wiz
What are you talking about??
Bob
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Bob
Thank you for flipping the stitch length jpg right side up. Now I can read the columns without hanging from the ceiling.
Posted IMHO, by Wiz
I thought he was posting about the 901M111, a very rare machine.
Art
