I bought a Maker stamp from Grey Ghost. I'm in the learning curve here. Every time I use it, I get a shallow impression. Then when I go to hit again, most time a get the double stamp look. The second one is off of the first so it looks blurred. I'm using cased leather, lining it up and giving it a good wack with a 24oz maul. For the second blow, I line up the impression with the stamp and give it again. Doesn't always work. Sure is disheartening when you finish a project and go to stamp it and then AGGGHHHHHHHHHH. &*$^@*$^@*&%#@@& Not Good. Any and all advice is appreciated..
Thanks,
Jon
Thanks,
Jon
Figue out where the stamp is going to go first...so if you blur and it is no good; you didn't f' up a finished piece:) (insert Superman dudududun du dudu) Captain obvious to the rescue! lolololdevil.gif
No seriously......
Try tilting the stamp after your first good whack forward back left right and then center again.Don't lift it off the leather! Hit is about 6 times!
Post up a picture of your stamp! It would help if I could see it...But treat it maybe like a cheap tandy letter stamp.
I think that's it. I used to do an incredible amount of hand stamping on steel, so I really understand the concept. The one thing you pointed out makes perfect sense. I am so used to Whack, let's see it, then realign and wack again.........F%$&&. Let me try Wack, tilt, Wack, tilt, Wack, tilt, Wack, let's see what we got. Perfect,
Thanks,
Jon
Loose the maul and get a dead blow hammer. Harbor freight sells them cheap. Push down on it hard as you are hitting it. Hit it hard. Move your stone to the cement floor for this stamp. Hit it hard.
Aaron
Aaron
Got it dead blow and swing like it comin' from Mississippi. I go past Harbor Freight tomorrow, will pick one up.'" I'm tryin all options. I want a nice, clean, legibal impression.
Thanks,
Jon
Do you have something solid that your stamping on ? A bench top won't work very well they bounce. When i use my maker stamp i just spay it with some water and hit it with a 24 ounce maul once on my tooling / stamping stone. If for some reason it doesn't look right put the stamp back in place it will line up fine ( fall into the impression you made ).
I have a steel leg workbench covered with a 1 1/2" laminate wood top, covered with a 3/4" piece of marble and then my 12" x 12" granite tooling stone. May be some bounce but I don't think much. I'll try the water idea on the stamp. And yes I am realigning for the second hit. Part of my problem may be that I take a lineup strike. You know like hitting a railroad spike with a sledge hammer. You take a short tap so you knbow were it is and then give it. I have never been comfortable just having at it with one strike. To many years in the die shop stamping steel dies. You always take the lineup tap, saves skin.
I set mine before I start and while it is a little wet hit it good one time then let dry some and reset it for the good burnished look. Sounds to me like you setting it at the end of your project and it is not wet enough so you get bounce. IMO
Mark
Mate, silly question but is the handle on the stamp removable ? If it is, stick the stamp and the cased leather in a vice, line 'em up and squeeze. I had a stamp sans handle made up by Jeff at grey ghost and find this method works well for me at least.
That little arbor press at Harbor Freight was made for this job. It will make a perfect impression every time with little or no effort on your part. :)
ferg
Mark
ferg
Ferg,
That is the first thing that came to my mind. Your arbor press. That has got to be sweet. I may just buy one to have it around.
I redid my bench a few years ago and though i'll fix it where theirs no bounce. On one end i made it solid 2x4 screwed and glued 5/8 plywood on top and it still bounced. Heck theirs still some bounce no much but some even with a 3 inch thick piece of granite. Set a full glass of water or lay a tool on your table and hit your stamp you should be able to tell if it has some bounce.
Edited by dirtclod
Cool thanks. I am going to do that.
  • 8 months later...
Yes a big hammer (preferably twice the size of your stamp) and a steady solid surface is essential.
You could also try branding with heat which is excellent if you don't want to scare your cat away while you do your branding.
If you're interested, check out our heat embosser for leathers: https://www.etsy.com/listing/98894284/custom-leather-stamp-with-heat-embosser?
