Today is my first day as a member, so here goes…I've read most of the posts here about Vinegaroon, but have a few questions after a recent project that was not as successful as I hoped. I'll start by saying that patience IS a virtue, just not one of mine (!).
I wanted to change the color of a sandy beige Coach bag to black. The surface was in really bad shape with blotches that I suspected were shoe polish and areas that looked and felt like they had been rubbed raw with sandpaper! But I only paid $1.00 for it and it wasn't usable as it was, so it became my first Vinegaroon adventure.
First I gave the bag a bath in warm water and Extra Strength Dawn dishwashing liquid. A good soak and scrub with my hands. I stuffed the bag with towels for a day or so, then removed and let air dry. The bath had little effect on the spots. I did not use a conditioner as I expected the experiment to continue, either taking it to a cobbler for a dye job, or doing it myself.
I mixed up 2 gallons of vinegar with 4 #0000 steel wool pads, cleaned and shredded in each. Shook them up, vented the lids and sat them in the Florida sun for 2 days. On day 3 I strained the liquid and made a big, rusty mess in the process. I dunked the small leather Coach hang tag in the strained mixture and it turned a nice shade of brown through and through, although darker on the suede side.
Day 4 I let the mixture continue to brew in the sun.
Day 5 I brewed some strong black tea, soaked the bag, re-strained the brew and dunked the entire bag for about 20 minutes. Followed with a baking soda bath, about 1/8 cup of BS to a couple of inches of warm water in the kitchen sink, for less than a minute. Finished with clear water rinse. The result was a darker brown, now with black spots where I suspected the leather had been abraded. I worked in a fair amount of Lexol while damp and it did darken the brown.
Then I started reading about deglazing, thinking it might help the surface take the Vinegaroon. I made a mixture of about 1/8 cup real lemon to about a quart of denatured alcohol. I sprayed it on, worked it into the surface and let it sit a while. Then re-dunked the bag for about an hour. I repeated the quick baking soda bath, a little stronger this time, and finished with a clear water rinse. I let it air dry a while and started working in Lexol again. The brown is darker and richer, but still has black blotches.
I've continued to condition with Leather CPR and cleaned the rusty fil off the brass hardware with NEVR DULL. I now have a nice, supple, usable, although fashionably distressed leather bag!
I know my haste was probably the biggest issue, as I did not let the Vinegroon either absorb enough steel, and I just didn't let it brew long enough. I expect to be whacked with a big wet noodle for this.
Should I have deglazed earlier in the process? Should I have used acetone or something else?
Should I have just poured off the top of the Vinegaroon, rather than straining the sludge?
Was it a mistake to re-use the Vinegaroon?
Was my dunk time sufficient?
Before and after:
post-30094-063029500 1332686519_thumb.jp
post-30094-098131800 1332686542_thumb.jp
I thoroughly enjoyed this process and thank all of the contributors for sharing their amazing wealth of knowledge in this forum!
I would greatly appreciate anyone and everyone's input, as there is another project waiting in the wings…and I really want it to be black! Thanks in advance!
  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
Awesome question and I am looking forward to what the experienced Vinegaroon users have to say.
Thanks for such a thorough and precise description of your process.
I am fifty years old and I have always lived in freedom; let me end my life free; when I am dead let this be said of me: 'He belonged to no school, to no institution, to no academy, least of all to any régime except the régime of liberty.'
"What we need is more cowbell!"
I don't use vinegaroon at all but from what I've read on making the stuff you need to let the steel wool dissolve for at least a week or two.
When you brew vinegaroon you're creating a solution of ferric acetate. The longer it sits, the stronger that solution will be. I'm willing to bet your results were caused by too weak of a solution to start with as you suggest.
I think it looks great myself. I think you got pretty lucky even if it didn't turn out how you wanted. :)
I think I would have deglazed after cleaning with your soap and water. The deglazer takes of the manufacturer's finish.
I have my first vinegaroon brewing now and though it's hard to leave it alone, I tested it on day 2 on a piece of scrap. It turned grey. I also tested it on some "tree of heaven" pieces of wood and they turned black, indicating a good amount of tannin in the wood. Hmmm... maybe that is a use for this awful weed tree? Anyway... I only brewed about a pint and a half. (ragu bottle) So I think perhaps you made quite a lot. I hope you have a lot of things to dye because I hear it does lose it's dying strength after a while.... though I understand that sticking another pad of steel wool in the brew will bring it back to strength.
It does sound like you had a lot of fun making over this bag though and I like the distressed look.
Can't wait to see how your next project turns out.
A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
deglaze after clening. It might not do much for a commercial bag. Your vinegaroon is not old enough. It needs at least 2 weeks then strain and let it settle. It should turn the color of tea.
wait until the vinegeroon is ready then try it all again.
Michael
The key to immortality is first living a life worth remembering.
Bruce Lee
I use rust dissolved in vinegar for woodworking and I've found you can jump-start the solution by starting off w/ rusty objects --- the rusty old Brillo pad from the kitchen sink, flakes of body work from an old clunker... (or get a bit of iron oxide from the paint counter at your local hardware store).
Very nice, very understated result on the case. Agree the de-glazing should have been part of the cleaning.
I'm very much looking forward to any advice I can get from this forum...there are certainly a lot of talented, experienced folks here!
Thanks for your encouragement!
Thanks for your comments! I agree that I was a little (!) impatient, but over all, I'm satisfied with the result...one small step on a steep learning curve.
Thanks again.
Indeed, I made a big batch, as I wanted to dunk the entire bag...and the next project is a bigger Coach tote bag (16" x 10" x 4" or so).
As Coach uses "glove tanned" leather (think baseball gloves), should I use a different deglazer?
I googled "glove tanned leather deglazer" and found references to acetone, oxalic acid and a variety of commercial products.
Any recommendations or advice?
I started the first batch of vinegaroon on March 13 and have re-bottled it after using it on this project.
Can I continue to use it as is, or should I add more vinegar and steel wool and let it brew some more?
Although this project was a big mess at various stages, I am pleased with the result.
I hope you will post about your experiences and wish you luck. Thanks!
Michael
Looking back, I agree the deglazing should have been done earlier in the process.
Should I use a stronger deglazer? Any suggestions are greatly appreciated! Thanks!
