IngleGunLeather Posted March 29, 2012 Report Posted March 29, 2012 (edited) Is there a special tool used to get the double groove decorative lines or is this typically accomplished by using a freehand groover? Edited March 29, 2012 by CountryTrash Quote Ingle Gun leather
Members Dwight Posted March 29, 2012 Members Report Posted March 29, 2012 I have two groovers, both bought at Tandy's, . . . one has a little screw in the very end of the center post, . . . it locks the blade into position. That one is set for all of my belt grooving and about 95% of my holster grooving, . . . and only gets moved when the blade needs changing. The other groover has a knurled locking band beside the wooden handle, . . . it locks the blade at any depth you want (dimension from the edge). I use it for the "second" groove on holsters such as you showed in your post, . . . as well as the other 5% of holsters. Hope this helps. And by the way, . . . that is one good looking rig you did there. I personally don't like one quite that fancy, . . . but some guys do, . . . and I do enjoy admifing them. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Ambassador Luke Hatley Posted March 29, 2012 Ambassador Report Posted March 29, 2012 Wing Dividers work fine for me.Then sometimes you can go back over the depressed lines with a modeling spoon. Quote Luke
Members Josh Ashman Posted March 30, 2012 Members Report Posted March 30, 2012 I typically use wing dividers to mark a light line then cut with a swivel knife and bevel. If all I'm doing is a "bead" then sometimes I'll just use the wing dividers. I purchased several creasers but never have nailed down how to use them. Here's one with cut and beveled lines. Best regards, Josh Quote
Phatdaddy Posted March 30, 2012 Report Posted March 30, 2012 (edited) I don't own one, but i think this would do the job, although it would cut the line in rather than scribe. https://www.tandyleatherfactory.ca/en-cad/search/searchresults/8029-00.aspx Kevin Edited March 30, 2012 by Phatdaddy Quote
Members Josh Ashman Posted March 30, 2012 Members Report Posted March 30, 2012 I don't own one, but i think this would do the job, although it would cut the line in rather than scribe. https://www.tandylea...ts/8029-00.aspx Kevin Kevin, I have one of these (ceramic double cut swivel knife blade) but it doesn't work well for me. It didn't cut well even when new and I can't figure out a way to sharpen it, so I just score two lines and cut them each. Best regards, Josh Quote
Members DaltonMasterson Posted April 1, 2012 Members Report Posted April 1, 2012 Most of the time, I use a wing divider to mark the lines, then cut with a swivel knife and bevel as well. I tried the ceramic double blade, and it didnt give me near as nice a result as cutting them separately. I have used my groover tools instead of cutting them, but its a pretty rare occasion when I do. DM Quote Specializing in holsters of the 1800s. http://www.freewebs.com/daltonmasterson/plumcreekleatherworks.htm
IngleGunLeather Posted April 1, 2012 Author Report Posted April 1, 2012 Most of the time, I use a wing divider to mark the lines, then cut with a swivel knife and bevel as well. I tried the ceramic double blade, and it didnt give me near as nice a result as cutting them separately. I have used my groover tools instead of cutting them, but its a pretty rare occasion when I do. DM Thanks for the information. I think the double cut/bevel would look much better than a groover. Quote Ingle Gun leather
Members DaltonMasterson Posted April 1, 2012 Members Report Posted April 1, 2012 (edited) It all depends on the look you are going for. Lots of Old nice holsters were grooved and not cut. I would think that most old shops would have used a groover, as its faster than cutting and beveling, and time is money... DM Edited April 1, 2012 by DaltonMasterson Quote Specializing in holsters of the 1800s. http://www.freewebs.com/daltonmasterson/plumcreekleatherworks.htm
Members katsass Posted April 1, 2012 Members Report Posted April 1, 2012 FWIW from the grumpy old guy; I 'taint an expert (EXPERT--- An EX; a 'has-been' and a SPURT. a drip under pressure) but I just used an old swivel knife with a filigree blade to cut the lines in this holster --- a copy of the original that's around 100 years old. Mike Quote NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!! At my age I find that I can live without sex..........but not without my glasses. Being old has an advantage.......nobody expects me to do anything in a hurry.
Members Ken Nelson Posted April 1, 2012 Members Report Posted April 1, 2012 FWIW from the grumpy old guy; I 'taint an expert (EXPERT--- An EX; a 'has-been' and a SPURT. a drip under pressure) but I just used an old swivel knife with a filigree blade to cut the lines in this holster --- a copy of the original that's around 100 years old. Mike I use a beader blade. Several good makers out there. Ken Quote
