Members WmWalker Posted April 1, 2012 Members Report Posted April 1, 2012 As the title suggests, I have the Tacsew T111-155 sewing machine. I purchased it for use on heavy duty nylon materials. It has performed flawlessly with this medium of materials. When I purchased the machine I did so with the intentions of only sewing nylon. Since then my interests have started to include leather. With that said; I have been reading all the posts I can find here that include my machine. Overall, it does not seam like a machine that is held with high regard within this community. Why is this machine not liked for sewing leather? Before I get hit with some of the more obvious responses, know that I understand that the machine would have to be set up differently for use on leather, I know I need the appropriate needles. I understand that the 155, although industrial, is definitely on the lighter side. I also know that I'm not in the market for another machine at the moment, and if I was I would get one to support my nylon sewing, like a bartacker, first. Quote
Members busted Posted April 1, 2012 Members Report Posted April 1, 2012 As the title suggests, I have the Tacsew T111-155 sewing machine. I purchased it for use on heavy duty nylon materials. It has performed flawlessly with this medium of materials. When I purchased the machine I did so with the intentions of only sewing nylon. Since then my interests have started to include leather. With that said; I have been reading all the posts I can find here that include my machine. Overall, it does not seam like a machine that is held with high regard within this community. Why is this machine not liked for sewing leather? Before I get hit with some of the more obvious responses, know that I understand that the machine would have to be set up differently for use on leather, I know I need the appropriate needles. I understand that the 155, although industrial, is definitely on the lighter side. I also know that I'm not in the market for another machine at the moment, and if I was I would get one to support my nylon sewing, like a bartacker, first. This machine will sew anything you put under the pressure foot as long as it is not over 3/8". It is an industrial sewing machine. I had one of these and loved it. Quote
Moderator Wizcrafts Posted April 1, 2012 Moderator Report Posted April 1, 2012 All you need to do to sew leather with your Tacsew is to slow down the motor (by installing either a variable speed servo motor, or by replacing the motor pulley with a 2 inch pulley and shorter belt), use smooth presser feet, and change to leather point needles. Using pre-lubricated thread will help cool the needle and reduce grabbing on dense leather. Do not try to exceed 3/8 inch of leather, or use thread larger than #207. It is best for the machine to stick with #69 through #138 bonded nylon thread. The denser the leather, the slower you must sew. While vests and chaps can be sewn at 20 stitches per second, an 8 ounce belt would have to be slowed down to about 10 per second, maximum speed. A double leather belt, 1/4 inch thick, might grab the needle at that speed, so it would be best sewn at no more than 5 stitches per second (~ one inch). Hold back the threads when you start sewing to avoid birds nests that will jam the bobbin and throw the machine out of time. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
KAYAK45 Posted April 1, 2012 Report Posted April 1, 2012 Since you KNOW these things, what is your question? I have a Singer 111-w155 is use weekly. What is the question??? Quote Once believed in GOD and the DOllAR...... Hello God!
Members WmWalker Posted April 1, 2012 Author Members Report Posted April 1, 2012 Wiz, I do have an upgraded servo with a smaller pulley and shorter belt. So it sounds like all I need now are needles and lubricated thread... and practice! Kayak, It seemed as if this machine isn't very popular within the leather community. I was wondering why. Quote
Members coryleif Posted April 3, 2012 Members Report Posted April 3, 2012 It's an inexpensive machine---not as well made as a Seiko STH-8BLD or Juki 1541 (two machines in the same weight class), but I love mine (and I have a 1541 too)...possibly the reason for the flak. Mine came with toothed presser feet, so, as Wiz said, you'll also need some smooth ones for leather (if you don't have some already). Should run you 'bout 15 to 25 bones depending on where you get 'em. Happy sewing. Quote
Cobra Steve Posted April 3, 2012 Report Posted April 3, 2012 Hi WmWalker. You might want to add a speed reducer. This will allow you to sew very slow without losing torque when sewing 20-24 oz. leather. Steve Quote Thank You Steve Tayrien Leather Machine Co., Inc. 2141 E. Philadelphia St. Unit "U" Ontario, California 91761 1-866-962-9880 http://www.leathermachineco.com cobra@leathermachineco.com
KAYAK45 Posted April 4, 2012 Report Posted April 4, 2012 this is a GREAT MACHINE if... you use it for what it was intended for. Gloves, canvas, parachutes purses, light weight leather,small belts, belt loops,etc. I have a previous post on how to slow it down with a larger top wheel and will not duplicate here! Do a search and find out how to utilyze this machine. (where the hell is the SPELL CHECK HERE?) GOOD LUCK, IT'S A great machine. Kevin Quote Once believed in GOD and the DOllAR...... Hello God!
Members SissipahawLeatherCo Posted November 25, 2015 Members Report Posted November 25, 2015 Mine came with toothed presser feet, so, as Wiz said, you'll also need some smooth ones for leather (if you don't have some already). Should run you 'bout 15 to 25 bones depending on where you get 'em. Happy sewing. Do you have a suggestion for where to buy smooth presser feet? I can't seem to find them anywhere other than smooth binder feet which I don't think I need. Quote Julia Sumner Owner Milestone Leather Taos, NM
Contributing Member TwinOaks Posted November 26, 2015 Contributing Member Report Posted November 26, 2015 If you can't find them locally, you might check with some of the sponsors of the site. There are ad banners at the top of the page. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
