Sorry, just checked my product bottles; I was mistaken - it's the Eco Flo Professional Finish (Clear Matte) that's been leaving white crud all over. The problem with the Block Out is it didn't work well (yellowed up the white quite a bit!)
Just floating around the forum and saw your question. I am not sure if you ever got an answer or not. I use a 50/50 mixture of resolene/water in thing layers. Approximately 3-4 layers. Allow each layer to dry before adding the next. I let my final layer of the mixture cure for at least 24 hours, more if I can. You always want to let your resist fully cure.
I have also read and seen lots of great resist work come from those that use Wyosheen. I have never tried it yet, but I plan to someday.
  • 3 weeks later...
  • Replies 44
  • Created
  • Last Reply
Top Posters In This Topic
I tried to use the antique paste several times, with and without Tan Kote, but finally gave it up. No matter how hard i tried, once it was dry, the whole paste flaked off.
Any tips what i might have done wrong?
  • 3 weeks later...
  • 2 weeks later...
does tan kote work as a resist to antique? Or is Super Shene the best option?
. I like angelus clear acrylic , to me it works much better than Tandys products
The light color you see on the projects is the natural leather with a finish on it. The antique (stuff in the grooves) is more than likely med brown antique paste by Fiebings or Eco Flo antique gel.
right, I guess my question is how do you keep that natural look? are they blocking out those areas?
  • 3 months later...
try wipeing th antq off with a damp finger rag,if not clean enuff try a damp alcohol finger rag then dry and re cover letters with your seal. a finger rag is one finger on a rag lol
Is it the same results when using Fiebings Antique Gel, waterbased? I have had some VERY different and frustrating results with it...
