Members yngliver Posted April 21, 2012 Members Report Posted April 21, 2012 Hello! I've been reading here for a while but this is my first post. I've been doing some simple leather projects for a bit and have recently gotten a Singer 31-15 for free. All in all it seems great, but I am having a hard time controlling it. I was looking for some opinions as to whether it would be worth changing out the motor for a Servo Motor. If so, which one. If not, any advice on how to handle the machine better? Thanks a lot for all the great knowledge on this site. Quote
Ambassador Luke Hatley Posted April 21, 2012 Ambassador Report Posted April 21, 2012 One thing to try is to install a 2" pulley on the motor. that will slow it down. Quote Luke
KAYAK45 Posted April 21, 2012 Report Posted April 21, 2012 For Singer info call Bob at Toledo Machine. He's the expert! I have a 31-15 using the Serve Pro servo from him and find it to be a great machine. Bolts in to your current holes and only needs a change of belt length. Totally changes the machine and makes it behave. Good luck. Kevin Quote Once believed in GOD and the DOllAR...... Hello God!
Members dscheidt Posted April 21, 2012 Members Report Posted April 21, 2012 <br />For Singer info call Bob at Toledo Machine. He's the expert!<br /><br /><br />I have a 31-15 using the Serve Pro servo from him and find it to be a great machine.<br /><br />Bolts in to your current holes and only needs a change of belt length. Totally changes the machine and makes it behave.<br /><br />Good luck.<br /><br />Kevin<br /><br /><br /><br />The 31-15 is an old machine; I've seen some that were in tables with weird arrangement of motors. A separate clutch isn't uncommon, for instance. (Some of these went into factories with line shafts and belts, so each head had a clutch, but several machines shared a motor. When the set is broken up, a motor was added.) Neither is a table that has two holes for a belt, expecting the use of a single length of leather belting, joined with clips once installed. A motor mounted to the back of the table rail might be another setup. If you've got a modern motor set up, it's straightforward to attach a servo motor. If you don't, it's more work. Quote
Members yngliver Posted April 22, 2012 Author Members Report Posted April 22, 2012 (edited) Thanks for all the input. I think I'll call Bob this week and see what he has to say. It is Toledo Industrial Sewing Machine correct? Edited April 22, 2012 by yngliver Quote
TZHunter Posted April 22, 2012 Report Posted April 22, 2012 I also recently acquired a 31-15 and had the same question ! I have already emailed Bob asking for a recommendation and price quote. I've heard Bob's servo has a built in speed reducer which others don't, is that right? What would be the result of using a servo (like on eBay for under $100) that does not have speed reducer built in? Thanks Quote
Moderator Wizcrafts Posted April 22, 2012 Moderator Report Posted April 22, 2012 I also have a Singer 31-15. It is very old and was equipped with a 1/3 HP clutch motor when I bought it. The motor pulley was 4" in diameter and the machine pulley is 3.5 inches. I figure it was spinning at about 30 stitches per second as setup. A couple of months ago I bought my second SewPro 500GR motor from Toledo Industrial Sewing Machines (866-362-7397). The first one is operating my National 300N walking foot machine. The new one is now powering the Singer 31-15.With its 2 inch pulley I can easily control the machine at all speeds, from well under 1/second, up to about 15/second. There is no lack of slow speed torque. There is a knob on the back of the motor that reduces the maximum speed, for even finer slow speed control. Because the SewPro motor has built-in 3:1 speed reduction, there is no need to add a reducer pulley. The same motor is sold as standard equipment with the Cowboy CB227R machines, which are medium duty walking foot cylinder arm machines. Before anyone asks, I don't think that this motor has quite enough umpf to direct drive a big 441 clone. You really do need a 3/4 HP motor for the big stitchers. It seems best suited for use with medium duty machines. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
TZHunter Posted April 22, 2012 Report Posted April 22, 2012 Thanks Wiz. Sounds like the perfect servo for my needs with my 31-15. Quote
Members Jimbob Posted April 25, 2012 Members Report Posted April 25, 2012 Free Singer 31-15?? Well, now you have some greens left and get a servo motor, then u mount.....big smile.....then u sew with utter control...biggest smile....then u buy later bigger machine and put servo motor on it....its all well, and u will smile from then on.....believe me....if you could see my face....!!! I am still smiling....bought two from Toledo Bob!! Smile James Quote http://www.elfwood.com/~alien883 First it is just leather....then it is what-ever I can dream off...
