Members Happy Hooligan Posted May 5, 2012 Author Members Report Posted May 5, 2012 Sounds like someone had an OLD J & K cluch motor replaced...and yes, that's old. right on the mark... and I have two more to replace in the future too.... Quote
Members corkscrew Posted May 16, 2018 Members Report Posted May 16, 2018 Can a servo motor be attached to a Singer 29U171A machine? Thanks Quote CorkscrewTom
CowboyBob Posted May 16, 2018 Report Posted May 16, 2018 Yes,you can by adding a piece of plywood underneath the back of the table(where the head mounts & run the motor belt to one of the pulleys underneath ,disconnect the treadle rod off the bearing & add a piece to it to connect to the motor. Probably won't any sense to you until you get a motor in your hand & then you should be able to figure it out . Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members corkscrew Posted May 16, 2018 Members Report Posted May 16, 2018 Thanks Bob, I haven't got the sewing machine, it's on it's way. Can you recommend a motor? Thanks again, Tom Quote CorkscrewTom
Members corkscrew Posted June 13, 2018 Members Report Posted June 13, 2018 Well I finally got my 29u171a Singer patcher machine. Having trouble getting it to feed the leather, stich and generally act right. This is my time using a machine and I have the manual and have read it thru several times now. Cleaned and oiled the machine per the manual. I have it threaded correctly, per the manual anyway. It's set up with 69 thread and a 29X4 needle. Doesn't want to pick up the bottom thread from the bobbin and when it does it bunches up in the bobbin and then stops. Also doesn't always feed leather along with the foot. I'm sure it's probably my in-experience in getting all the tensions right, but I'm getting a tad frustrated. Any pointers, ideas, suggestions would be appreciated! Thanks in advance. Quote CorkscrewTom
Moderator Wizcrafts Posted June 13, 2018 Moderator Report Posted June 13, 2018 3 hours ago, corkscrew said: Well I finally got my 29u171a Singer patcher machine. Having trouble getting it to feed the leather, stich and generally act right. This is my time using a machine and I have the manual and have read it thru several times now. Cleaned and oiled the machine per the manual. I have it threaded correctly, per the manual anyway. It's set up with 69 thread and a 29X4 needle. Doesn't want to pick up the bottom thread from the bobbin and when it does it bunches up in the bobbin and then stops. Also doesn't always feed leather along with the foot. I'm sure it's probably my in-experience in getting all the tensions right, but I'm getting a tad frustrated. Any pointers, ideas, suggestions would be appreciated! Thanks in advance. I recommend that you start a new topic for this, please. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
