So how many occupants are living in the doghouse tonight?
CTG
LOL! Yes, she is not to happy with us right now....
Bob
There are always possibilities....
Bob Blea
C and B Leathercrafts
Fort Collins, CO
Visit my shop at http://www.etsy.com/shop/CandBLeather?ref=si_shop
Instagram @bobbleacandbleather
  • 5 years later...
On 6/7/2012 at 0:17 PM, northmount said:
Add any additional finish coats, mark, punch and install the metal rings. I used 1/2 of a Chicago Screw, a nickle plated 8-32 oval screw and an upholstery type trim washer to attach the rings. Glue the screw threads so they don't unscrew over time. Because of the shape of the rings, I had to add a spacer under the rings so they could open fully otherwise they were limited by the spine.
northmount, I know this is an old post, but this is the info I am looking for to finish several binders I have in progress.  Do you have any photos that illustrate how you use the spacer, Chicago Screw and oval screw in sequence?  Many thanks in advance!
YinTx
YinTx
I'll put together a little sketch early next week.
Tom
YinTx
Sorry I was so slow getting back to you this week.  Too many things got in the way.
See sketch in attached 3-ring binder clip.pdf and example hardware photos.  You will have to play with dimensions to suit your clip.  The spacer is a piece of 1/4" NC Hex Nut.
If you are removing a binder clip from an existing binder, drill the smallest hole that will remove the rivet.  Then you may be able to save any spacer they have used.  I didn't realize there was a spacer there so had destroyed it!
Edited by northmount
Replaced 1/4" tubing with 1/4" NC Hex Nut to correct this post. Uploaded revised pdf.
Northmount,
Awesome, thanks for the detailed instructions.  Is the spacer you speak of the one that is already built into this 3 ring binder that I bought, or do I need to add one to it?  The other thing I am struggling with is finding a chicago screw with a diameter small enough to fit into this spacer - none of the ones I have do.
YinTx
You might need to remove this spacer and make your own if an 8-32 Chicago Screw is too large.  You can see how long it needs to be and cut tubing to fit.  I'm trying to remember if I used tubing.  I may have used a hex nut as a spacer.  Likely 1/4" NC.  I know I started out trying to use a piece of tubing, but when you mentioned that the Chicago Screw won't fit the existing spacer, I doubt that it would fit 1/4" tubing either.  Memory is less than perfect!  Have to go check now to see.  Will edit this after I check it out.
Tom
Edit:  Okay, the shank of the 8-32 Chicago screw just nicely fits through a 1/4" NC hex nut.  So I'm pretty sure that is what I used instead of a piece of tubing.  You could pad that with an extra washer if you need more height, or use a stack of washers.
Edited post above to replace 1/4" tube with a 1/4" NC Hex Nut.
added comment
