esantoro Posted January 17, 2008 Report Posted January 17, 2008 Do those of you who wind bobbins by hand or by drill ever feel that sometimes bobbin tension isn't as consistent as it could be if wound on the machine? I had liked the idea of not having to run my 441 just to wind bobbins since I have only one cone of each type and color of thread, but bobbin tension doesn't seem to be consistent. I also think that when I do it by hand or by drill I've got to pay more attention to which direction I wind the bobbin, clockwise or counter clockwise. I think I just may go back to prewinding bobbins on my machine and cut out another variable in the guess work. ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Moderator bruce johnson Posted January 18, 2008 Moderator Report Posted January 18, 2008 Ed, I really don't see a noticeable difference. Some I wind on the 2000, some I do with the drill. If I have a long run (rein day), I wind all the empties I have at once on the drill. Faster for me to do that than to change out bobbins on the machine, set the next one, do it over. I don't much care for the winders that bind on the belt, so I never installed it on the 1245, all those I use the drill. I tension with my thumb and forefinger, so tension is pretty consistant. I dont see tension as much of a factor, as long as it is consistant. The biggest tensioner is on the bobbin case, not how tight the bobbin is wound on the spool. Biggest advantage I have with doing them with the drill is I can evenly wind them. No glob in the center and tapered ends. That is what catches and binds sometimes as you sew. My experience. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Contributing Member barra Posted January 18, 2008 Contributing Member Report Posted January 18, 2008 Threading the bobbin thread thru the tensioner disks on the winder is a pain in the backside. I tension by running the thread around my shears handle or by using the thumb and fore finger depending on my whim at the moment. Bruce, doesn't your 1245 have a bobbin winder on the front of the arm???? Barra Quote "If You're not behind the Troops, please feel free to stand in front of them"
Members bcurrier Posted January 18, 2008 Members Report Posted January 18, 2008 Applying tension only aids winding the bobbin. It doesn't add tension to the bobbin thread itself. There is no thread tension in the windings to speak of. The only tension provided is by the bobbin case. Bill Quote
esantoro Posted January 18, 2008 Author Report Posted January 18, 2008 Applying tension only aids winding the bobbin. It doesn't add tension to the bobbin thread itself. There is no thread tension in the windings to speak of. The only tension provided is by the bobbin case. Bill I was thinking that if the thread is not wound on the bobbin in a consistent fashion, the thread would not pull of the bobbin in a consistent manner. Lately, I've had a few bobbin threads snag on the bobbin spool itself, nothing else. I attributed it to my hand or drill winding: too tight , not tight enough. ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Moderator bruce johnson Posted January 18, 2008 Moderator Report Posted January 18, 2008 Barra, I have Ferdco's 1245, a clone of the Pfaff. Nope, no bobbin winder on the machine. Good little machine though. I have had it for a year, still waiting for the first skipped stitch once I got the tensions set to my likings. Apparently there are other "1245s". On the boot and shoemakers forum, they talked about about the 1245, but one that is a post machine totally unrelated in any recognizable form to the Pfaff or the clones of it. Silly me, I thought I knew the answer. Ed, I think the key to bobbins is to have an even tension and wind them level. A softer lie and then harder tension over that can dig a thread in, and it may drag when feeding. If the drag is more than the cast tension, it will pull tighter. That would be the only situation I could see where bobbon winding tension could be an issue. Likewise an uneven bobbin where the thread is feeding from low, and rides into the blob of thread above it and catches might be a problem. Think level-wind like the old baitcasting fishing reels. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members Ken Nelson Posted January 19, 2008 Members Report Posted January 19, 2008 I use a remote bobbin winder and they can be purchased, factory made for about $100.00. I built one, used belt driven industrial winder, put a household sewing motor on to drive it and it works great. FAST, with a lot of control and cheap to build. I mounted it on the wall out of the way. Handy as all get out. Quote
esantoro Posted January 19, 2008 Author Report Posted January 19, 2008 Barra, I have Ferdco's 1245, a clone of the Pfaff. Nope, no bobbin winder on the machine. Good little machine though. I have had it for a year, still waiting for the first skipped stitch once I got the tensions set to my likings. Apparently there are other "1245s". On the boot and shoemakers forum, they talked about about the 1245, but one that is a post machine totally unrelated in any recognizable form to the Pfaff or the clones of it. Silly me, I thought I knew the answer. Ed, I think the key to bobbins is to have an even tension and wind them level. A softer lie and then harder tension over that can dig a thread in, and it may drag when feeding. If the drag is more than the cast tension, it will pull tighter. That would be the only situation I could see where bobbon winding tension could be an issue. Likewise an uneven bobbin where the thread is feeding from low, and rides into the blob of thread above it and catches might be a problem. Think level-wind like the old baitcasting fishing reels. Bruce, If you wind by hand or by drill, do you have to make sure the bobbin spins clockwise or counterclockwise? ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Moderator Art Posted January 19, 2008 Moderator Report Posted January 19, 2008 Hi Ed, As most bobbins are symmetrical, that doesn't make any difference. However counter clockwise is faster when you figure in the rotation of the earth. Art Bruce,If you wind by hand or by drill, do you have to make sure the bobbin spins clockwise or counterclockwise? ed Quote For heaven's sakes pilgrim, make yourself a strop!
esantoro Posted January 19, 2008 Author Report Posted January 19, 2008 Hi Ed,As most bobbins are symmetrical, that doesn't make any difference. However counter clockwise is faster when you figure in the rotation of the earth. Art Should I also account for gravitational pull and altitutde? Seriously, I read or heard somewhere that because of the way the thread is twisted winding one direction or the other affects how the thread will come off the bottom. One direction will allow the thread to fall off the bobbin too easily rather than staying wound. I haven't really noticed any difference but it sounded as if it made sense. ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
