A question that is often asked is how heavy a leather a machine will sew and while this is not definitive and there are exceptions the following might help.
DBX1, DPX5, Domestic Needle: Light only - Garment leather with #69
DPX16, DPX16: Light to medium, generally to 7-8mm depending on the design of the machine with 138-207 thread
DDX1, 328: Medium Heavy. Depending on the machine 10-12mm. Anything up to #415
794, 7X3 Very Heavy. 18-22mm Any thread commercially available.
This is not meant to be definitive. There are all sorts of exceptions and I would appreciate feedback from our more knowledgeable members and dealers.
Most needle systems come in a wide variety of sizes, or more specifically, thickness of the blade of the needle that is penetrating the work. For example, a very common needle system, 135X17 (designated above here as DPX16, a cut point needle designation) comes in sizes ranging from NM70//10~NM230/26. As you can see, this is a broad range for a very common needle.
Aside from thickness of needle, the thread, any size thread/needle, must be able to pass through the needle eye freely without getting choked off. This, again, does NOT designate the sewing machine capacity to sew through high piles of dense materials.
It's a common misconception to think that, because you put a thick needle into a machine that it will do heavier capacity work. Yes, you will get less bending, deflecting, and can sew heavier goods, no doubt. What you may not have is a machine with the drive it may need to do heavy webbing, slings, cargo nets, or the such, in some cases.
When we speak about drive, I like to use the analogy I would overhear my Dad tell people; drive is when you take a board in your hand, and I try to hammer a nail in by hand in the air; there is little drive behind it. Now, if I can take that same board, hammer and nail, and lay the board flat on concrete, there would be more drive behind it , and would be easier to nail into the board. This is drive, more or less, and all machines have more or less of it. It's a lot more than inserting a fat thick needle into a high speed garment machine and sewing auto trim with it.
Edited by Gregg From Keystone Sewing
Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Wiz,
Did it look like this?
Bob
YES! Where did you get it? Does it sew and move the leather along on its own, or do you have to move the shoe manually?
Posted IMHO, by Wiz
It has a little arm that comes up & pulls the leather back.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
I guess the one I used to have was missing that feeder. I had to move the shoes manually to stitch them. PITA! It would be nice to have another one, but RedDevil76 may want it more than I do. I would rather have a curved needle Frobana.
Posted IMHO, by Wiz
The technical term for that being "GRUNT" :thumbsup:
There always exceptions and a good example is the Singer 42-5. It only takes a DPX16 but it will run any thread that will go through the needle as that was what it was designed for with that bloody great hand wheel. It will do things that would give a Chinese GC0302 a haemorrhage! And of course it can do all of that as a treadle (my favourite type of drive).
What I was trying to give is a general idea of machine capacity not a definitive one. In my business I seem to spend nearly as much time educating people about what the term "industrial" really means as I do selling machines, although I mostly find that spending the time to explain and referring them to sites like this actually sells me more machines. It is often better to give people the resources to confirm what you have just told them so they can see you are being honest. Those who do the research tend to give me the most repeat business!
I will have to do a test-to-destruction on a GC0302 type machine with a heavy weight flywheel and upgraded tension just to see how well they are built.
Darren Brosowski
