amuckart Report post Posted August 6, 2012 I'm making my first gusseted bag, and I'm wondering if anyone can share tips on getting the gusset to go around the corners neatly without wrinkling or getting bad folds that make it impossible to machine sew? I'm using chrome tanned leather for this project, so wet forming isn't an option. Thanks. Quote Share this post Link to post Share on other sites
dirtclod Report post Posted August 6, 2012 If i'm going around rounded corners i glue the gusset to the backside first and use binder clips to make sure things where their supposed to be and sew taking the clips off as i come to them. Then i do the front side the same way. Square corners i can't help ya. Quote Share this post Link to post Share on other sites
Rawhide Report post Posted August 6, 2012 I Like dirtclod, I too use binder clips. I glue with leather weld about 4 to 5 inches at a time. I let it dry under clamp, then move to another 4 to 5 inch section. It's easy enough to do it this way without too much trouble. Marlon Quote Share this post Link to post Share on other sites
amuckart Report post Posted August 6, 2012 Thank you both. So far I haven't needed binder clips, the contact adhesive I'm using is more than strong enough. The difficulty I'm having is in getting the gusse to form neatly. How much sewing allowance do you leave on the gusset, I.e. how big is the turned out lip? Thanks. Quote Share this post Link to post Share on other sites
Rawhide Report post Posted August 6, 2012 I've never had any issues with it forming. I usually glue up to about 1/4 to 3/8 of an inch from the edge. I sew closer than that but that's the distance I use. Quote Share this post Link to post Share on other sites
Jbarv Bulls Report post Posted September 12, 2012 Do you wet the gusset before you sew it? I normally end up with my presser foot not being able to traverse the excess leather waving up around the corners on my Toro 3000 with a double toe. Quote Share this post Link to post Share on other sites
Ferg Report post Posted September 12, 2012 If you wet the leather before sewing the feet will mark your leather pretty bad. It should dry I think, at least that is the way I do it. ferg 1347486521[/url]' post='264170']Do you wet the gusset before you sew it? I normally end up with my presser foot not being able to traverse the excess leather waving up around the corners on my Toro 3000 with a double toe. Quote Share this post Link to post Share on other sites
bruce johnson Report post Posted September 12, 2012 I use a stirrup throat plate. It makes it much easier to get into and around the inside corners rolling over the smaller radius of that plate than the others I have. Quote Share this post Link to post Share on other sites
dirtclod Report post Posted September 13, 2012 I tried a stirrup plate and it set the foot over to far to suit me espically having to use a right toe foot. For me a holster plate works lots better because i can use a left toe foot and sew closer to the edge. Quote Share this post Link to post Share on other sites
Jbarv Bulls Report post Posted September 13, 2012 I thought the wet tracks would sure enough show, so I never tried it. I may have to try out some plates and see if that helps. Thanks fellers. Quote Share this post Link to post Share on other sites
