Members CustomDoug Posted September 19, 2012 Members Report Posted September 19, 2012 I picked up some Diamond Hone Blocks from Harbor Freight for my sharpening duties.. a couple of the reviewers (on their website) mentioned that their diamond surfaces delaminated from their heavy duty alloy steel frames. Another reviewer (who loved these hones) mentioned that this delamination was probably due to them using OIL for lubricating, said that was a no-no. He supposedly used dishsoap and water. I'd be concerned with that on metal blades, wouldn't it cause rust or oxidation? Is there a better lubrication I should get? thanks. Quote Does Anyone Know Where the Love of God Goes When the Waves Turn Minutes to Hours?
Members CustomDoug Posted September 19, 2012 Author Members Report Posted September 19, 2012 ..oh, btw - that reviewer said that the oil dissolves the glue. I'm not trying to have that happen if I can help it. Quote Does Anyone Know Where the Love of God Goes When the Waves Turn Minutes to Hours?
Members evandailey Posted September 20, 2012 Members Report Posted September 20, 2012 Soap and water is all that is usually recommended for diamond hone sharpening. If you're worried about rust just give the blade a wipe with a little WD-40 sprayed on a cloth. A very light coat is all you need. Quote
Contributing Member TwinOaks Posted September 20, 2012 Contributing Member Report Posted September 20, 2012 You can use just about anything, really. All you're doing is providing a medium to "float" the small bits of metal that are removed from the blade, which keeps the stone from clogging up. After sharpening on a stone, it's a good idea to also strop the blade to polish out all the microscopic grooves from the 'stone'. After that, wipe with a lightly oiled rag/cloth then dry the blade for storage. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members HellfireJack Posted September 20, 2012 Members Report Posted September 20, 2012 Soap and water is the way to go. Here's a thread from the forum with a video on sharpening a round knife with a diamond hone. http://leatherworker.net/forum/index.php?showtopic=28376 Not sure the harbor freight hones go up to 1200 and 8000 grit Quote
Members CustomDoug Posted September 20, 2012 Author Members Report Posted September 20, 2012 Thanks you guys. I'll proceed with the soapy water then. As far as the actual using of these stones... do I just try to follow the beveled angle of the very tip of the blade (1/16" apprx)? I mean the main angled part needs no attention, does it? I'm off to research strops now. Quote Does Anyone Know Where the Love of God Goes When the Waves Turn Minutes to Hours?
Members CustomDoug Posted September 20, 2012 Author Members Report Posted September 20, 2012 Soap and water is the way to go. Here's a thread from the forum with a video on sharpening a round knife with a diamond hone. http://leatherworker...showtopic=28376 Not sure the harbor freight hones go up to 1200 and 8000 grit WOW! That video is awesome, very helpful. I learned alot and will keep it as reference. No, my HF hones are way off those numbers... we're talking #200, #300, #400 @ #600. I do have some 1500 wet dry sand paper though. I suppose I could use that as a final before the strop-ing for the time being. Quote Does Anyone Know Where the Love of God Goes When the Waves Turn Minutes to Hours?
Northmount Posted September 20, 2012 Report Posted September 20, 2012 Thanks you guys. I'll proceed with the soapy water then. As far as the actual using of these stones... do I just try to follow the beveled angle of the very tip of the blade (1/16" apprx)? I mean the main angled part needs no attention, does it? I'm off to research strops now. Depends on what the blade is. Swivel knife, maintain the full angle. Don't do a micro bevel on its edge. Regular knives, chisels, etc. work on the micro bevel. After a long period of use or damage due to improper usage, then the edge may need to be ground back and reshaped. Then a micro bevel done on the edge. There are a lot of posts on sharpening different types of knives. Do a search for the type you are sharpening. CTG Quote
Members CustomDoug Posted September 20, 2012 Author Members Report Posted September 20, 2012 It's the 4-3/4" splitter blade of Tandy's small "High-tech" bench mounted splitter. I'll see if I can find any specific details for sharpening splitter blades. That angle on the tip is really small though. Quote Does Anyone Know Where the Love of God Goes When the Waves Turn Minutes to Hours?
Northmount Posted September 20, 2012 Report Posted September 20, 2012 I'm no expert on splitter blades, but ... Since the blade is relatively thick, I would do a micro bevel until such time as it is getting too wide, then reshape the edge and apply a new micro bevel. Same as with many woodworking tools like planer, jointer, plane blades, etc. It's a lot quicker to touch up the micro bevel and to strop it than having to work the whole surface each time. CTG Quote
