RockyAussie Posted December 14, 2017 Report Posted December 14, 2017 16 hours ago, Anubis78 said: RockyAussie, I need something that looks like the second foot or a compensating foot. I'm assuming that the second one is a guide foot. I'm looking to sew two straps, of different widths, together. I want to insure that my stitching is exact along the edge of the top (smaller width) strap. Ok I did a test for you of the above feet supplied by Ewe and the pictures show the results. The top strap would need to be more than 2mm thick or youd need to sand some off the bottom edge of the foot to go any thinner. The distance from the edge is 1/8" or 3mm if you like. The centre/front foot fitted straight on no problem but I did have to grind out the slot a whisker on the back foot but that is more than likely my machine a bit. Metal is hard and the quality is good. If this is what you are needing let me know if you have any trouble getting one there. Brian Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
