RoosterShooter
How Can I Retrofit My Shop Press 'on The Cheap'?
I picked up a used shop press today from a yard sale. The owner said he only used it 2 times to remove bearings from a truck that he was working on, and I was all to glad at the price I paid?
Being that it's so close to Christmas ... funds are tight. However, I still need to get rolling on pressing holsters.
So, how can I retrofit my shop press to wet form holsters ... on the cheap?
For the info ... it's a 20 ton, standard style floor press made by Grizzly.
i would think 2 1 inch steel plates welded to the frame and ram, along with some gum rubber, and you would be set...gum rubber is around 50-60 bucks i think, and the steel, im not really sure...
I already have the steel, but can't come to grips with buying rubber from McMaster Carr since it's $100 for the size needed.
Would the foam used in Kydex holster making work?
This guy uses kydex foam
Also, find someone who installs carpet, they may have a lot of scrap carpet foam and just give it too you.
Where would I get something to use like the part that is on his 'arbor' of the press? It's the top piece that comes in contact with the foam.
That I don't know, maybe you can go to his site and email him. He might just tell you.
It looks to me like a tamper used to tamp down a sand base when laying a brick walkway. http://www.lowes.com/pd_162933-42268-KR-2F-K+/+33962_0__?productId=3589556&Ntt=tampers&pl=1&currentURL=%3FNtt%3Dtampers&facetInfo=
You will find that a 20 ton press is FAR more than enough to press holsters, . . . I did it for years with one made out of 2 x 4's and used a small 6 ton bottle press, . . . it gave me way more pressing ability than I could ever use.
The bottom and top plates can be made out of 3/4 inch plywood, . . . a double layer, . . . screwed & glued wil be quite sufficient.
The reason that the latex rubber is used, . . . it does not mar the surface. ANY foam that is not perfectly flat, . . . no bubbles, . . . WILL mark the leather.
I gave up using a press a couple of years back, . . . I get much better results with a vacuum bag, . . . less space taken up, . . . and I never have to worry about the possibility of messing up a gun when I use the vac bag, . . .
Make one extra, too many pumps on the press, . . . break a gun or somehow mess it up, . . . and a $50 holster profit just became a $1000 business liability, . . . to say nothing of the bad press he'll give you.
May God bless,
Dwight
Take a look here: http://leatherworker..."holster press"
Edited by Dwight
You can get a 1" x 24" rubber sheet from MSC for $83. Cut it in half and you have your two 12" x 12" pads. Here's a link.....http://www1.mscdirect.com/eCommerce/NavigationServlet/Raw-Materials/Rubber/Rubber-Sheets/_/N-77dswZ1yxfh4aZ1yxgndu?refinement=4288835349&searchandizedOk=Y
Check out my blog. I built my shop press and posted the pictures/details on there. Good luck!
